Adjustable diff?
FL
I want to install the adjustable diff on my mb. I know you have to raise the diff, but wouldn't you also have to raise the motor up so that rear brace is level, or am I not thinking clearly? Thanks
MN
I show you how to do it on the R&D page. http://www.molzermoweryracing.com/sasrandd
I mounted the adjusted diff on 6mm risers, but I also had to jack up the rear of the engine mounts to get the gears to mesh correctly. Easy, but it wouldn´t have worked without raising the engine just a little bit.
I made my own risers from a plastic cutting board, works perfectly.
Stefan
Stefan
Well, I considered elcon mounts or fg risers, but they just cost too much when I could make my own in ten minutes for free. Besides, I didn´t want to wait for a packet to arrive either.
Stefan
Stefan
i would never ever cut in my chassi :| it needs all the strengh:P i rather just make some simple risers instead
well in the future that is:P when i buy myself a new diff
I am actually considering milling a slot in my chassis even though I have risers. There is plenty of space under the main body of the diff but not under the higher part. It would feel better to have a slot under there just in case a stone tries to get under. But as it is stones get pushed to the side and clear under the diff anyway... so it´s no biggie. It´s most a matter of me being too lazy to unscrew everything from the chassis... I might dremel from underneath though but I dont know how pretty that would look in the end...
Stefan
Stefan
MN
ORIGINAL: StefanL
Stefan
Stefan
I used the FG riser block with the FG LST diff on my Firehammer and had no trouble meshing the gears with the stock motor mounts. I had already rasied my rear bulkheads before the diff change (thanks for the tip Sandy@Mozler) and made a small spacer block for the overhead triange bracket.
I reused the home-made overhead spacer with the new FG riser block. The overhead block is probably 2-3 mm taller than the bottom spacers but it doesn't seem to be an issue (yet
Ken
)Ken
