RADIO GEAR?(SPEKTRUM)
MN
RE: RADIO GEAR?(SPEKTRUM)
Question on the spring idea. I saw a post a while back that mentioned installing a spring to pull back the servo in case of servo failure. Question is would the spring not be a great deal of stress on the servo which could in return cause the failure of it? You would need a pretty tuff spring to pull back a high torque servo, or would it only need to pull it to neutral?
WA
ORIGINAL: bigger the better
MN
PICS???
Sorry, where would I connect it too? and again would not the servo need to pull back the spring for the spring to pull back the failed servo? I must be missing something.[]
