What kind of oil should I use?
Hello everyone. I'm not sure on the type of oil I should use? I work at my local motorcycle shop on the weekends and all the service guys told me that Klotz is the best oil for pre-mix 2-stroke engines.I will be running a duratrax firehammer and a HPI baja 5B.Will Klotz be ok to use on my cars? Thanks for your time.
Banned
RE: What kind of oil should I use?
i ve been looking at moveing to klotz for the Baja and the Bergonzoni. my family has been useing clotz for years. always good. looking into they stynthetic blends.
Timmahh
Timmahh
CA
Klotz makes probably 6 different 2 stroke oils. Klotz Beanol is a bean/castor oil and although that has ultimate film strength, it's a nasty gummy oil. Klotz Techniplate is a synthetic oil with a little castor oil in it. I'd only use Beanol that if i were running a old 125 2 stroke in the dunes that is jetted too lean. Motul 800 or Motorwerks is a ester based synthetic (clean burning) that is actually a group 5 oil which is the cadillac classification of oils and has about 98% of the film strength of a castor/bean oil with none of the gummyness. I'm not trying to pimp a certain brand oil or anything but mabey look into an ester based synthetic oil. Just trying to help.
