What compound are the stock MT tires?
CO
I run on very dry,rocky, abrasive terain and my stock rear tires are about half gone. I'm just looking for a longer lasting tire, mabey a harder compound would be better. Any thoughts?
WI
RE: What compound are the stock MT tires?
Mine was shipped with two M tires and two H tires.
Obviously medium and hard.
I run the hard on the back so that the truck doesn't understeer so much. I'm not sure if they make a harder compound for the stock tires.
My Firehammer has the stud tires. I have no idea if the compounds are different. The rears have worn down. Because there is no known difference between front and rears I have been rotating them occassionally to even out the wear.
Since you may have different compounds on your MT tires rotating probably wouldn't be a good idea in that case.
