Tips and Hints for new FG MT owner
soon ill have my FG MT , and i have been reading on this forum about littles things that can be changed on the MT to make it handle and a little stronger . so far i have gotten > the shock oil/fluid needs to be changed to 50wt in front - 70 in rear .
tyres need foam inserts . dont run a K&N filter run the standard with a pre filter . ok what else is there to know.?
TX
RE: Tips and Hints for new FG MT owner
[8D]I would get a good pipe[sm=idea.gif] Myself I like the Jetpro v2 with or with out the silenced muffler. It bolt's on around 1.3hp[sm=thumbup.gif] If you get the pipe I would change the gearing to 18/46, it gives you more controllable wheelies & more top end & just the steel pinion that way you still have one weak link. Also don't forget to get a wheelie bar. I jot mine from here->[link]http://www.largescalerc.com/Tunedpipes.html[/link]
AB, CANADA
Dont use loctite on plastic parts. IF ANYTHING a small amount of tire glue.
Loctite will eventually strip the plastic threads unless the right 'plastic loctite' is used wich I am unsure of the name as I have yet to find any..lol.
ORIGINAL: D0G
ASSURE Threadlocker 425
For use in place of
anaerobic threadlockers
on most thermoplastics (ABS, PVC, etc.).
A low strength, fast surface curing threadlocker for plastic and metal fasteners. Can be pre- or post-applied.
Applications: Plastic and metal fasteners.
http://www.gluguru.com/loctiteanaerobics.htm
WA
ORIGINAL: quantum2plus2
LOCTITE
For use in place of
ORIGINAL: D0G
For use in place of
VA
The loctite that you can use on plastics is called epoxy. Oh and another upgrade that would be very effective but very cheap is a gear cover. Only about $20, and get a return spring on the throttle lever on the carb.
i was thinking of using liquid electrical tape to hold the screws in plastic , as its ment to stop them from viabrating loose . but u can still remove the screw without snapping the head off it .
If your new to 1/5 scale & this will be your 1st, i wouldnt jump right in & splash out £££ on a tuned pipe, if you do you will notice no benefit!
stick with stock for a while then when you want more speed get the tuned pipe then the £££ youve spent on it will be well worth it & you will notice the difference!
i have heard the stadium foams work great in the MT tires ! next time mine come off i'll give it a try as well
ORIGINAL: savvy-racer
do i need the foams for the tires or no. thanks
AB, CANADA
MN
ORIGINAL: D0G
Unless you were given the option to purchase your truck with tires mounted and glued, I do not believe they come with foam in the tires. And my opinion is yes they are needed for the tires to perform properly.
ok , i have ordered the following :
alloy layshft gear carrier, elcon upper rear arms , stainless steel diff case , alloy engine mounts [ both big and small], foam inserts for MT tyres .
one question regarding the recoil starter -- duz the air holes need to be covered with foam or anything to stop the dust and dirt from geting in there and causing the starter not to engage .[ iv herd the baja b5 suffers from this probblem] and i didnt know if the FG`s do too?.
CT
Hi jasrx,Lots of people have tried to cover that themselves.Try this you can get them at www.largescalerc.com they have different colors and a much better price than from outerwears themselves.
CT
Hey J D if you go down a couple of threads here to the one that says outerwears covers the post from scooter trash is at the bottom of the thread.Sorry I didn't know how he got that page either[:@]Give that a shot[sm=thumbup.gif]
TX
[8D] Hi frumpy, Troy just srarted to get them in & hasn't updated the web site yet. I did order one from him & I should get it next week[sm=thumbup.gif] I E-mailed him & asked if he was going to start to carry them? Then he E-mailed me back & said yes!
