FG part number??
CT
FG part number??
Hey guys can someone tell me the part # for these FG side guard/body mounts?Some sites have alot of FG parts listed but no pic to go with the part#[][&o]
PA
RE: FG part number??
Frumpy! I have the FH and I looked up the part on the website. I believe it is called the "Sid Body Mount Set." Since they are both about the same, here is the DuraTrax part number.
DTXC6561 SIDE BODY MOUNT SET
Again, they didn't have any pics but I am sure if you call durtrax they could tell you.
Hope it helps,
Paul
Hope it helps,
Paul
WA
ORIGINAL: jpachill1
Hope it helps,
Paul
Hope it helps,
Paul
But here is where you can get the ones for the firehammer
http://www2.towerhobbies.com/cgi-bin...?&I=LXHTP3&P=Z
CT
Thanks Hellya and FG perf RC,I'm trying to mount a VW body on my hammer.I just checked the price of the FG mounts and they are like $19.00 for 1 piece.[:@]I guess I'll have to make some kind of mounts myself[&o]
ORIGINAL: frumpy
In order to mount that body you will need to start with FG part # 6203. It is the body undertray that mounts to the chassis so that it will hold the Beetle body.[link]http://www.molzermoweryracing.com/download/marderbeetlepajero.pdf[/link]
PA
ORIGINAL: hellya
They are not the same the body mounts are in different spots
ORIGINAL: jpachill1
Hope it helps,
Paul
Hope it helps,
Paul
Thanks Hellya, I was just trying to help.
Just out of curiosity, couldn't you just drill new holes for the body mount pegs? They just pop in, so I guess it is possible. I ask in case i would want to put a different body on.
Paul
CT
Damn[:@]Those under trays are expensive @ over $100 bucks a pop it's time to go another route[]Any suggestions?I do like the asgard ST body.Can I use the single front long mount and the leopard side mounts?I work in the machine tool field and make some of my own alloy parts when I can.I've already made the front long mount and mounting plate I think I can make some side mounts.I just need to know how far out the hole is for the body clip from the edge of the chassis. Anyone with a leopard out there can you get this dimention to me?Would be greatly appreciated[sm=thumbup.gif]
PA
ORIGINAL: frumpy
Frumpy, in that case I would make my own too.
CT
I think I'll just forget about a different body and spring for a tuned pipe instead.At least I know it will fit and I'll alter the hammer body for that!![sm=spinnyeyes.gif][sm=thumbup.gif]
