Selwa's Leopard Race
ON, CANADA
RE: Selwa's Leopard Race
Thanks Fred! You should have seen it at Clarkson on the 28th, 4lbs of mud was on it!! Doug and I will have to check out that oval one day!
Take a peak:
http://www.rcuniverse.com/forum/m_4927601/tm.htm
The red are from Krikke Racing. They are avaliable in blue as well. These are made by Elcon and Krrike are only authorized to sell them in those colours. I've had chrome on my Marder and wanted something different. The cables are also from Krikke and are very smooth compared to the FG cables. You can also get red or blue but it started to dis-colour so I removed the shrink wrap. (yes it was only shrink wrap) I have some clear I'll put on before I run it. Plus here in Canada there are not many guys who have FG Leopard's
Take a peak:
ON, CANADA
Close to! I still have the engine mounts plastic though. Since the screws and washers are recessed into the chassis I don't have a problem with the engine moving. I still have a spare set of rear uprights and Abec bearing fit inside great. I thought about the Krikke uprights but they use smaller bearings. I like to have some soft area in the back there just in case!
