Baja engine stutters at top end?
My Feedback: (7)
KS
My Baja 5B engine seems to run great except when it hits the top end it kinda stutters or cuts in and out somewhat, not a smooth sound like you would expect. Low end and mid-range sound good. What would be the cause of this? Is it too rich, or is there something else I need to do to get it running smoothly? It is the stock engine with an X-Can exhaust, running 87 octane with 25:1 Amsoil Dominator oil if that helps at all...
Thanks...
Thanks...
My Feedback: (7)
KS
RE: Baja engine stutters at top end?
Thanks. That's what I figured it was. Ran outta gas before I had a chance to fiddle with it, but I'll lean the high end down a bit to smooth it out as soon as I gas her up again Thanks again...
ORIGINAL: TheFgMan01
your H needle is a bit too rich... lean it out and it'll sound smoooooth
Banned
QUOTE: Allready been awnswered in previouse tread reply
QUOTE!
Allready said in previouse response. Repeating somthing said accomplishes nothing!
ORIGINAL: 34Ford
Sounds rich to me. Lean bogs.
Just turn the H screw a 1/16th each way from where it is now and run it. Simple.
My Feedback: (7)
KS
Haven't had a chance to adjust it yet, but will tommorrow. I'm inclined to think it's too rich, and leaning it a smidge would fix it. Anyway, I'll update tommorrow which way it needed to go, ie rich or lean...
Dion
Dion
ORIGINAL: R.Robinson
QUOTE!
ORIGINAL: 34Ford
And your telling me I cant say what I want when I want.
A person can turn the screw both ways and you will see the results. Try it, you'll see.
