Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Giant Scale Cars
Reload this Page >
Will not start after stall. See inside for details
RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Old 11-25-2007, 09:34 PM
PBJT
PBJT's Avatar
Default Will not start after stall. See inside for details
I did a quick search but really nothing as to what I have. I was not driving the FG MT at the time with a stock 26 Zen with a FG tuned pipe at the time so I don't know if it slowly got sluggish but it did stall and will not re start. Although I was present and operating the Marder so I know it did not die out due to water.
Symptoms-
-The truck was being operated in wet mud, temperature outside was just above feezing point.
-I noticed no excessive smoke out exhaust while it was operating
-truck has alot of oil residue out exhaust oil soaking body and rear shock.
-air filter is soaked in raw gas.
-alot of fuel/oil spraying out spark plug hole while pulling cord with no spark plug.
-plug is fuel soaked.
-new plug did not fix
It seem flooded but the raw gas on the airfilter is odd and alot of fuel coming out plug hole and if tipped upside down fuel runs out head. Should I start with carb problem or piston ring? or?
PBJT
Old 11-25-2007, 09:41 PM
hummitlargescale
Default RE: Will not start after stall. See inside for details
You sure exhaust is not plugged with mud? just thought I ask it happens to my firehammer all the time
Old 11-25-2007, 10:57 PM
PBJT
PBJT's Avatar
I checked it. The exhaust is clear. Thanks though. I'm thinking all this fuel running back into the air filter is a sign of something.
PBJT
Old 11-25-2007, 11:16 PM
Nathan9492
Nathan9492's Avatar
Is it even sounding like its attempting to fire?
Old 11-25-2007, 11:23 PM
krayziedxc
My Feedback: (9)
i say dismantel it. and find out ur problem, sound like bad carb, and bad piston head. ignition switch mayb?
Old 11-25-2007, 11:29 PM
Nathan9492
Nathan9492's Avatar
Have you checked ur kill switch?, IF u have been running it mud, some coulda go into ther and dried the Killswitch closed.
Old 11-25-2007, 11:55 PM
badz
badz's Avatar
sounds to me like it swallowed a bunch of dirt and wiped the cylinder and piston out
Old 11-26-2007, 02:02 AM
hathi
Banned
clean it down, throw in a new plug and remove the air filter and try to start it up. if the the filter is soaked in fuel its like have the choke on
Old 11-26-2007, 02:37 AM
Mudgy
Mudgy's Avatar
always check these 3 things -
Does it have compression?
Does it have spark?
Does it have fuel?
These are all you need to start a mower...right up to a 100T truck. They all work the same
This year I had to repair a brand new leaf blower - one of the welch plugs in the carb came loose, flooding the engine.
is your fuel clean?
sometimes dirt & dust can work its way to the H & L needles, too.
Old 11-26-2007, 06:42 AM
PBJT
PBJT's Avatar
Thanks for the advice. I am going to try to get it going again today. I know it has good spark, plug is new again, compression is there but seem a little easier to pull over then the Marder engine, Has a whole lot of fuel....
PBJT
Old 11-26-2007, 06:57 AM
wildchild45177
wildchild45177's Avatar
If it is flooding without any changes to the needles, I would guess dirt in the metering valve. I mostly run two stroke gas in planes, but a Walbro is a Walbro, or Zama a Zama. The carbs all work the same. If the metering valve is stuck, it will either have no fuel or too much, depending on which way it's stuck.
Bob
Old 11-26-2007, 07:44 AM
Osirisf16
Osirisf16's Avatar
WHAT A BASH, INDEED!!! However, i agree with Mudgy. If its not start, the only faults are 1)no fuel, 2)no spark, 3)no air. In your situation, plus the dirty "inside of engine" . I can get that you had your best times ever there
Old 11-26-2007, 10:38 AM
PBJT
PBJT's Avatar
Was as many guess water sucked in. I looked and smelled like fuel running out but did not burn on the bench. So after draining and drying, then a few pulls it started up and stumbled for a few minutes and cleared out. Thanks all for your advise and hopefully this will help someone else later on.
I would estimate total amount of water drained is between 1 and 2 tablespoons.
PBJT
Old 11-26-2007, 12:11 PM
Dave ESPI
Dave ESPI's Avatar
Glad it runs again. Be sure to post that pic in the messy cars thread
Old 11-26-2007, 03:25 PM
Osirisf16
Osirisf16's Avatar
Yeah, but don't forget to post more pictures on that kind again. I love them
Old 11-28-2007, 11:36 PM
Mudgy
Mudgy's Avatar
That's right...dirty cars are fun cars!
Show the shelf queen owners and say "that's what these were made for!"
