Baja SS Shocking Shortcoming
NOTE to all you companies that make parts for the Baja the Baja SS 6mm Shock Shaft with the pressed on plastic end is a very good place to make a new shock shaft that the end user can change the plastic end! This weekend racing the new buggy that shortcoming was discovered this minor thing took a few people out.
But this is what racing does for you is focuses on parts that can take you out of a days race.
RE: Baja SS Shocking Shortcoming
Last I heard phatdads all were already not sure about the RC4WD ones but the rest already are.Nothing new here that the bashers haven't figured out already.
LOL then why did all the bashers who showed up not have any?
Never the less its a part that needs to be updated out of the box.
Who knows why they didn't have them. Why don't you ask them yourself. Better yet, take it up with HPI as they may be covered under warranty. Incidentally the plastic ends are not press fit they are molded on. This is directly from HPI. The PhatDad shock shafts have been out for a couple months for he RTR baja and the RC4WD shocks. They will be available, if not already, within a week from DDM for the SS. The SS shock shafts are obviously crap. I have seen some builds where the threaded portion where the piston is has fractured/sheared off. This happened from trying to remove the nut not installing the nut. The shaft material looked pretty bad.
CA
If the PhatDads for the SS are anything like the shafts for the RTR whey will be a racers dream.
Darksoul has a set of shocks that will be a welcome addition to the lineup as well.
We spent an entire day trying to bend them doing nose dives off a 4 foot jump and they held up great.
Hopefully they will be out soon.
The stock shafts have been a week spot from day one and there are several products out there for them now and several more on the way.
Nope this is a photo from another forum. This member had built his shocks. Didn't like the feel of the 5wt oil so went to disassemble them. Upon trying to remove the nut with almost no torque this is what happened to all four shocks. Unfortunately for the member HPI will not have replacement parts til Jan.
Press fit molded on what ever they are a one shot deal that is not up to bashing or racing for now plus no factory parts in stock.
Who has the upgrades in stock?
CA
So far its the only report that I have seen of this issue of braking the threads on the shaft.
Many cases of the Diff housing being damaged have been reported.
I also heard that the entire first 2 shipments of SS are already out of the hands of HPI and into the stores.
Hopefully they have time to correct a few packaging issues and the shafts before the next batch ships out.
lets keep out fingers crossed.
PRESSED SHAFT ENDS.
K-Spindle, this was something I was goiong to adress when I was done with my build in a Likes/Gripes wrap up at teh end of it. I like the fact they came on the shaft from the factory as it's always a scary thing having to hold onto a shaft and worry about scratching them up with a wrench or plyers while screwing the heads on them...... but I agree that the design and metal used for them felt and sounded a bit "chintz" even though they are "beefier" than the stock RTR ones. For just all around running, they should be "OK".... I forsee myself destroying them with how I drive.
CA
ORIGINAL: Dave ESPI
Banned
BC, CANADA
Is there anyone else making upgraded shafts? Does anyone know if rc-edit will step aboard?
I've seen those other ones and the price tag just scares me away.
ORIGINAL: hathi
ORIGINAL: K-Spindle
TX
If Phatdad is making shock shafts for the SS you can bet they will be great. I just got a set for my Baja RTR and they look the business. You don't hear of anyone saying they bent the Phatshafts.
Cool! There is a race and have fun event this Saturday at SV
Bruce Slawson owner of 2 wheel Hobbies needs some he was one of the drivers who was short shafted last weekend at the Toys for Tots Race.
Can you PM me I want to buy set to have on hand in case a racer at this weeks race at SV has the same issue.
Banned
ORIGINAL: K-Spindle
You get what you pay for. Quality does come with a price. But you chose to buy cheap. That's what these type of rc are cheap[] RTR.
