fs racing 4wd?
#527
RE: fs racing 4wd?
I'll monitor the steel gears, but I went easy on the car for about 10 mins then ran it quick. did some cool downs and low speed to ensure everything is working right. one less thing to worry about. no worries of it breaking now from either stress or from a debris. metal gears should be stock equipment on all large scale vehicles.
#528
MD
RE: fs racing 4wd?
Hey I've been reading this thread all night and personally I think gasoline is the way to go. I've been religiously hooked on nitro cars and for the last 3 years and engine rebuild/replacement, tuning woes, differential rebuilds, wheels and tires, BUYING $30 of nitro every 2 weeks or so killed all the money I SHOULD have put into these cars. So yesterday my 1yr old 4tec 3.3 blew its 3rd 3.3 motor and I cant take it ANYMORE. Im keeping my brand new 4tec roller (shelf piece), getting rid of all my other nitro products and after I get back from basic, I am buying a FS MONSTER TRUCK!!! So after reading all the stuff on this thread I know I have to take it apart when I get it, install all new sealed bearings, get new servos (waterproof/HT metal gears), change the gears to alloy, change the gear carrier to alloy, get new shocks and oil, get a tuned pipe, metal shock towers, get new radio ( Spektrum 3.0), Zenoah Coil MSD Plug wire & Cap ,TGN Kill Switch and finally medium loctite all the metal to metal, am I leaving anything out? (besides obvious spares) also what octane gasoline works best? Please let me know what I'm missing and or what else I need for a bad***** baby eating FS MONSTER 4x4.
__________________________________________
No actual thoughts of babies being harmed was used to create this POST.......
#530
My Feedback: (16)
HI
RE: fs racing 4wd?
ORIGINAL: bentley marshall
center diff mounts allso get alloy ones and the cheapest place to buy the parts is fsracingusa.com
#531
RE: fs racing 4wd?
i havent bought any thing yet but i did email them to find out when they would have some things in stock and got reply with in 24 hours
i will be ordering some bits of them soon ...when they have the bits i need back in stock
#532
RE: fs racing 4wd?
Hi there, welcome aboard to large scale vehicle's. ....make sure to budget for
a new engine, the one it comes with is poop, then your away laughing
#533
RE: fs racing 4wd?
Hi there, welcome aboard to large scale vehicle's ....make sure to budget
for a decent engine, the one it comes with is poop, then your away laughing
#534
RE: fs racing 4wd?
Hi there, welcome aboard to large scale vehicle's ....make sure to budget for
a decent engine, the one it comes with is poop, then your away laughing.
#535
RE: fs racing 4wd?
hi and welcome i got it news aboyt fsracing usa the fs company are going to stop selling the cars to them as why i am not to sure so whatch out and if you would like the fs4wd then i suregest going to http://www.x-rover.com or http://www.kooltoyz.co.uk/ i know that cooltoys have the cy motors and xrover have only the 30cc poop engines and at the moment x rover a 15% dicount selling the fs2wd buggy for $509 and 4wd$ 799
here is what you need to get the car in top con
alloy servo try for the hitec servos
alloy body posts x8
alloy diff holders
alloy gear holder
shims to shim the drive line up as it needs the types of shims are in the book that comes with the car
some good diff greas fg is ok
steel gears for the monster or buggy
2x hitec servos HS-5745MG + 2x HS-645MG
zenoah 27 4 bolt new motor or the old 26cc oh dont get confused about the 27 zen this is also 26cc its just the 27 is the new inproved unit
http://www.pitstop-shop.nl/ fiter system they have a compleet set filter and oil and cleaner i have been useing this for the last 3 years
and the mcd shocks
and a set of fg wheels seconed hand or new or you can go to http://www.rc-car-online.de/ and get ya self a set of mt ones from carson only €79.90 + shipping and a good radio system with eneloop batteries x8 as these are the best on the market and the hpi hump back battery 4200 nimh fits lovely in the battery box
oh and when ordering the car make sure they send the car with the extra servo pulling rod as you will need this if you are going to use the 2 hitech steering servos ok hope that helps
and 8 heat sealed dust prof wheel bearings
alloy body posts x8
alloy diff holders
alloy gear holder
and the mcd shocks
#536
RE: fs racing 4wd?
Well for the past few days I've been busting around the FS Racing Buggy and trying to get it going. The work has finally paid off, the car is running like a champ this is using the included 30cc motor.
Upgrades are the aftermarket jetpro style pipe, and rear MCD shocks, MCD servo plate, and new radio setup (MX-3 2.4GHz FHSS radio, 2000mah lipo receiver pack, 3x Hitec 5745 servos), steel gears. Th
It goes like heck, not much ground clearance with the included wheels but I'm happy that it's running and turning so well. Dual steering setup is definately recommended makes a worlds of a difference in handling.
#537
RE: fs racing 4wd?
yes, I have a King Kong 4x4 1/5 scale truck. DO NOT BUY FROM OVERSIZE.COM!!!!!!!
he sound good and yes I received my truck but after that you are on your own, they are "F" for helping or anything that is wrong when you get your truck or car.
I found FSracing.com and they will help and back up there product and have great shipping to you.
I had to buy a new receiver "FM" and transmitter (the one that came with mine was "AM" and it took off on me two times) that made a BIG differance for the better.
I put in upgrade parts on front end - the plastic parts were too weak and than my back hubs went out on the tires. Yes the tourqe took out the square hubs. I heard that there are some upgrades for that too.
so right now - I have it running great with tune pip, but down now waiting on new wheels. I have not jumped this yet as the shocks already bent at the bottom.
So yes you will spend more $$ on upgrades, but I think long term it will be worth it.
Dale from FL
Dale from FL
#538
RE: fs racing 4wd?
hi all
so ive been reading the thread regarding thses trucks on rc independent and i am impressed with the work these guys have done on these trucks,
it is in german but the pictures explain alot
btw since upgrading my truck i have no problems at all.
nice to see new users with the truck...now all we need is pics and vids
regards
regards
#539
RE: fs racing 4wd?
short vid of my truck, h needle needed a bit of tuning and i think my back diff blew..[]
http://s533.photobucket.com/albums/e...iew¤t=007.flv
[img][/img]
[img][/img]
#540
RE: fs racing 4wd?
FS*MT*4WD on you photos on photo bucket you have your front main drive shaft has rubber boots on it were they on your truck or did you put them on ??? what are they off
#541
RE: fs racing 4wd?
hi
they are from the baja 5b. but better ones are
http://www.raceparts-zeller.net/index.php?cPath=75_96
#545
RE: fs racing 4wd?
just fitted some mcd brake pads in to my fs they fit mint the mcd ones are a bit skinner and they use 4 pads in sted of 3 i put 2 pads in the middle between the discs seems to work mint havent driven it yet .... its one thing i realy like about the fs it has great brakes
my old pads broke the corners off where the rods go thru and were jaming
#547
RE: fs racing 4wd?
hi all try the abs system on the radio i mean if the fs radio has this set up then surely the more exspensive one will have this set up also
and if you are a good driver the breaks dont have to be used that much i dont brake that much
hey fs mt 4wd you should post that pic of that alloy diff box looks real nice thats on my want list now just need the price
#550
RE: fs racing 4wd?
nice i like the side plates it was a mt write its just looking a bit to low are the shocks long like the mt or are they the truggy shocks you have on there or is all the shock oil gone
