King Motors Baja Review with pictures
#226
MA
RE: King Motors Baja Review with pictures
ORIGINAL: hellya
its comming frrom china so about 5-7 days after its sent from china it will be in the states...took about 3 weeks for darkfire to get his from vtec
Got my km running again.... the coil had to much of a gap....no spark.... reset the gap with my trusty business card even added a tunedpipe
Nice getting it running again hellya! I just got home from school so Im gona see if i can get her started.
Edit: Started up right away. I took out the spark plug and messed with it, making sure it was nice and tight inside the coil. I think the carb, plug/coil are bad, thats all thats really wrong with it.
#227
VA
ORIGINAL: DarkFire989
Yeah it was a pain to get mine. I bought it on the first of april. It didnt come till the end of the month. Its stupid because he doesnt even have them in stock yet when he sells them so once they arrive he sends them off. Once shipped though it only takes 5-7 days.
ORIGINAL: hellya
#229
My Feedback: (9)
ORIGINAL: hellya
#231
VA
Yea you have to have the item on hand but w/e. Anyway on subject. Was charging my battery (you could probably guess what happened) and all of a sudden I hear a psffffffff. I'm like ****. I take the buggy otu side take the radio box and this battery just blew up. I was like what!? So I'm in the process of making my own right now. Also on the side note it does come with a 2000 mAH battery.
#233
VA
ORIGINAL: hellya
i toosed my 2000 out and snagged a 4200 from just batteries $36.99
#234
MA
Took the baja to the local park, I had not been there in awhile and was quite dissapointed with the park, there were no more sand dunes in the way back But the baja was fun as hell. There was a steep hill though with a sandy path and I had fun doing hill climbs with it.
#235
VA
ORIGINAL: hellya
#236
WA
guys get the dominator tuned pipe[X(]....it never fails to amaze me what a nice expansion chamber in a tunedpipe can do for performance
before pipe video http://www.youtube.com/watch?v=r1zUMuMkbDQ
after pipe video http://www.youtube.com/watch?v=AsaPT01jW80
#237
VA
ORIGINAL: hellya
Amazing difference huh? I love it man.
#238
WA
ORIGINAL: jtnktz
Can I get a link to this "just batteries".
ORIGINAL: hellya
http://www.onlybatterypacks.com/show...temID=11292.17
#240
My Feedback: (9)
i think you guy may need the chrome ring for your wheels for the KM wheels..looks too me that hpi wheels have the chrome rings in the inside. might save you from destroying your wheels like mind
#241
VA
ORIGINAL: krayziedxc
#244
VA
^ yup just giving heads up. same o minds already almost hpi.
Well I ordered my hump pack. I ordered the one with just soilder tabs as I will just put my own plugs on. They charge 10 bucks for the plugs...
#245
Hye Jtnktz do you have a pic of that fence lol?
Also what have you upgraded so far since im still looking around fore a used baja b5/researching the km baja.
Also hellya the pipe gave you stacks more power!
#246
jtnktz :
that would be nice
i havent bought one yet, but im looking on ebay
This is not true. I have found many problems with it. I will list all of them one of these days.
that would be nice
#247
VA
ORIGINAL: naynay12
#249
VA
[ul]
Problems:[*]Tires wear out quick[*]Metal is cheap
[ul][*]Main drive shaft to differential bent due to so much torque after jump[*]The back A-arms bend very easily[*]Clutch broke[/ul][*]Flipped and broke the spark cover and spark plug[*]Battery blew up on me
[ul][*]During charge[*]Undergoing slow good charge with Superbrain 977 (I know what I'm doing)[/ul][*]The coil lost gap[*]Dog bones suck(Pins fell out)[*]Pull start
[ul][*]Plastic Paw stripped inside the pullstart (Pull put no turn over)[*]String broke off[*]Screws on KM pull start will not fit HPI pull start (Rethread HPI pull start)[/ul][*]1/4 scale Servo
[ul][*]Hit a rock and popped it out of joint[*]Took apart and accidentally touched the motherboard[*]Replaced with Cirrus (Spell check?)[*]Only turns 70% left and 30% right[*]Will replace with good servo when I have the money[/ul][*]Broke servo saver
[ul][*]The turn buckle between the actual saver and servo horn stripped and popped out[/ul][*]In order to fix a KM differential you have to do a complete switch with a HPI
[ul][*]Cannot use parts from HPI differential and put on KM differential[/ul][*]High response clutch springs will not fit the KM clutch
Normal stuff:[*]Broke bumper[*]Broke front shock tower[*]Broke front bottom A-arm[*]Broke the flywheel cover holder that attaches to rear.
[ul][*]Twisted it then snap (User error)[/ul]
Hop-Ups:[*]DDM rear dominator
[ul][*]Burned roll cage (Was not installed properly)[/ul][*]Spark Plug Wire (MSD)
[ul][*]Great heavy duty[*]Will need to bend spark cover (Warm it then bend it)[/ul][*]Proline Badlands
[ul][*]Went on perfectly no problems[/ul][*]Anything that was broken was replaced by stock HPI stuff unless was upgraded.
[/ul]
All I can think of right now.
[/ul]
