radio/bearing question?
i have a few radio questions, hoping you guys might be able to answer.
i have a 2ch dsm, will that work or should i see if i can pay the difference and upgrade to a 3ch one? answered
if i use my 2ch, i know the fail safe is not enough, and i would like a remote kill switch, so could i use a wire harness on both, so both the fail safe and kill switch both run at the same time?
is a 144oz a good enough throttle and brake servo? or should i use my tower pro995mg servo, from what Miami has said its 193oz? answered
whats the bearing size to replace the bushings in the diff?
(this is all pertaining to my purchase of the baja 5b ss)
also does anyone have a link to the kill switch that u can use if i had a 3rd channel? answered
RE: radio/bearing question?
Do not use the Tower pro 995mg,it is the most glitchy servo i have ever had.And it also suddenly went weeeery slow,it took the servoarm 3-4 seconds to return to neutral some times,i dont know what happened.I found out it is a too cheap way to destroy my car by using this servo
IN my openion..I would get a Futaba 3Pm from tower for 199 bux..DDM Daves discount motoers has the kill switchs you
are looking for..AKASlawhammer
ORIGINAL: slawhammer
thanks for answering 1 3 and 5, i still need to know.
____________________________________________
well i got off the phone with spectrum and they are not gonna let me upgrade to the 3ch so, i need to know if Q 2 and for before i cna do anything else.
CA
Bearings are a 10X15X4
Need 2 of them to replace the bushings or 4 if you want all of them to match.
http://www.teamfasteddy.com/index.ph...products_id=57
