wats the difference?
RE: wats the difference?
hope there is sumting like wikipedia where we can chk wat does 1 stroker mean..1 stuff stroker mean etc...good for newbies to understand...thks
ON, CANADA
Here is a web page describing a stroker crank. You can move the stroke by 1mm or 2mm to give the engine morre performance but you have to watch the piston does not hit the to of the head when it goes up. That is called the squish. A stuffed crank is when they fill some of the crank with material and that reduces the volume in the bottom end which will give more pressure for the fuel stroke of the engine.
http://www.powroll.com/tech_specs_st...howitworks.htm
ORIGINAL: part-time
the stock has a 28mm stroke the +1 is 29mm. stuffed cranks the xtra area around the crank is filled in to increase crank case pressure for more power.
