Baja 5B SS build!!!!
GA
RE: Baja 5B SS build!!!!
Looking good. I still do not have my 5B SS running as I am doing many up grades before I ever do. I hope to be done with phase one soon. I do recommend doing the front hub C clip up grade ASAP. I all so recomened a fail safe kill switch as this can end up saving you a LOT of money!!!!!!! Here is a list of what I have so far.
HPI Baja 5B SS Kit
Team Associated throttle brake
DS1015 servo
Turtle Racing
Complete Clutch System (Orange)
Turtle Racing
HD Tranny Plate (Orange)
Threshold
Shock Umbrella Seals with installation tool
Turtle Racing
Heavy Duty Front Chassis Brace
HPI
Front tire molded foams
washers for e clip conversion
Fast Eddie
Wheel Shim Kit
Scorpion Chassis Brace Satin
Pro-Match 6v 4200mAh Hump Receiver Battery
FF Front/Side Windows Smoked
Modified Pico Failsafe / Soldered Kill Switch Combo
Bad Horise Shock Covers
Heavy Duty 20T Drive Gear (Will not install till I have the other gears)
Outerwares pull starter cover
PhatDad Fan Cover Saver
HPI Baja 5B SS Kit
DS1015 servo
Turtle Racing
Turtle Racing
Threshold
Turtle Racing
HPI
Fast Eddie
Wheel Shim Kit
yep these things take time do do right... im building my dads right now(well took a brake to look round here) lol
1 question. the plugs things that hold the radio box down mine are short and i cant put the clips through???
i did cheach the part numbers twice acually
any help will b apprecated
GA
The front and rear radio box pins are different. The front ones are smaller so they can fit through the frame and are held by the front brace. Hope this helps. I enjoy my build.
ok ill keep trying... its nearly done just 1 front and the rear shocks togo
broke the oring in the front shock so have to wait till hobbie store opens to run my car
GA
ORIGINAL: d.k.v
nope not long enough
All so if you do not do the C clip mod on the front wheel hubs sooner or later your wheel will fall off.
http://www.asaad.com/eclip.htm
All so get a fail safe, kill switch as I have read of many that did not run one and they ever did HUNDREDS of dollars damage and luckily never hit any one. This type fail safe does MUCH more then a normal fail safe!!!!!!!!! Would not run my 5B SS with out one.
http://www.rckillswitch.com/index.html
GA
I sell nothing and do not make money trying to help others from wasting there money and making mistakes. I do do a lot of reading on many forum sites and learn from their problems as well as my experiences. If you run the stock C clips your wheels on the front will fall off sooner or later and a Pico kill switch is MUCH cheaper then what it would cost to fix a run away 21 plus pound RC buggy or keep the possibility of a law suite if it hits someone or personal property.
GA
I have not run my 5B SS yet as I am fixing all the weak spots and doing many up grades. I have had it for all most 2 months but all most done with phase 1 and will be running it in the next couple of weeks as the last parts for phase one are on there way.
This is my first 1/5 scale but have been racing 1/8 scale and running nitor for about 10 years religiosity. I have played around with them off and on since around 1965 when I got my first one.
What radio are you going to use?
CT
Once you start with these you will not go back to nitro,and the building is just starting,wait to you see what you can get and add on to these things.lol
GA
ORIGINAL: CTDave
Thinking about building another 5B SS just to run alcohol some day.
GA
ORIGINAL: d.k.v
where runing a spectrum dx3s with telematary(once we workout how to set it up) lol
will kick my cars but
CT
I am hoping with more and more of the big ones getting around,there will be more tracks being built for them,I was heavy into the nitros too but these are more fun.I do miss my MGT's though.
GA
I am trying to get more in to racing 1/5 scale here in Georgia and there is a new track about 70 miles away that has 15 foot lanes and he is talking about trying to run some 1/5. But it is pretty radical for 1/5 but is great for 1/8.
Very nice looking kit coming together there!
Dont skimp, keep up the good work. Even though you investsed 20hrs into building, that will be worth it. When I built my first comp gasser kit, I did it in about 8hrs. Not too long, but not too fast either. But I goofed on a couple of areas where I wound up having to back track and redo it because I didnt look at the instructions thoroughly. (I was too excited in getting it up and running)
But seeing you SS kit coming together brings back that feeling of elation of the actual build process and the anticipation of wanting to get it together to run it!
building it is the best you can see your hard work coming togeter.and if you brake it you know how it goes together so you can fix it easyer
Oh, absolutely! It is to the point now that I will buy the kit version anyday over the RTR. For one, I hate the stock electronics, (I have a race grade radio).
Also, I believe every RC fan should built at least one kit in their life. Kit building is part of the hobby and I hate how RTRs are beginning to ruin that.
At least HPI makes kits, like the Savage SS kits, and this beloved Baja 5B SS kit. I cant wait for the 5T to come in an SS kit too! (Too bad Traxxas, AE, and Losi do not sell any of their RCs as kits, at least none that I can think of)
yer i have a tamiya tt-01 kit that was fun now i just fined my dads baja ss so im goin good.
but i also have a traxxas slash rtr :0 but still awsome fun like a mini baja 5t
GA
I know AE make buggy and truggy kits. I have not bought a RTR in years other then a couple of my Kyosho Mini-Z F1 as they do not come in kit form. To me starting out with a RTR just ends up costing you more money in the end. I only have around 35 RC vehicles as a couple years ago I sold some. [X(]
