home made hop-ups on the cheap
I had a couple of days to kill,so instead of ordering and waiting for days sometimes weeks for parts to arrive ,i made my own.For my light pods, i use the extra hub arms from my 5b and for the pods,i use a led bulb.My MCD RR has the medium travel shocks at the front,i wanted the front long travel kit but it cost about 200 bucks!I have a couple of aluminum plate lying around which i use for the plate which i cut using a mini hacksaw.Cutting was easy,filling it straight was the hard part.It took me a day to complete the part.Although it's still look like it was "home made". A couple of hours more i could make it look like it was milled.I did the same procedure for the rear hub support plate.
RE: home made hop-ups on the cheap
If you hadnt mentioned it i would never beleived this was homemadeVery,very nice work here!I have made some stiffening braces on my FG too.It is very nice to know you have made something yourself that looks -or almost- looks factory,at least it is as functional[8D]
BC, CANADA
here's a full brace I made for my rampage...I had the local fab shop weld it why I held it together..It aint perfect but it works real good. Gonna fab a 4130 full cage next that'll take 37ib dropping on it. I also made the limiting straps and dual steering servo bracket. I wish I had a machine shop or access to one...handtools severely limit what I can make
AB, CANADA
ORIGINAL: itlog
