single speed v/s 2 speed
trying to figure out something here.
lets say you have the same 2 trucks with same mods , but one with the 2 speed and 1 with single speed. and both are geared correctly for the track(drag racing only) which one would be faster and win?
would the 2 speed have more low and top, or if the single speed geared right get more low and top?
NS, CANADA
RE: single speed v/s 2 speed
An engine has a power curve. You can move the curve back and forth compared to rpms by changing gearing. So with a single gear transmission, you can gear for strong low-end power, but it gives up topend. Or vice versa.
With a multi-gear transmission, you widen the curve (measured at the wheels) to include more top end as well as more low end.
A 3-speed will broaden that curve even more....widens the useful power range.
so going 2 speed will definetly get more speed in low on top end. so it would beat a single gear in winning the drag race righ?
