firehammer mt alloy gear carrier
LA
hi everyone madforce again, going to order g260 Zenoah from ddm motors jetpro pipe toewr has a 14t pinion metal going to run 48t plastic. What i want to know who has a alloy gear carrier oras firehammer calls it spur gear mount. Pleas help.
RE: firehammer mt alloy gear carrier
That 14 tooth gear is the transfer gear ..it goes on the lay shaft to diff gear...
you want a 19tooth steel pinion gear.....the alloy gear carrier can be found at large scale alloy or known as innovative hobby
they have both the 19th tooth gear and alloy carrier....for the firehammer
