what parts can i use
hi lads and lasses
my name is steven and i,m realy just getting right back into rc cars now that my wee lads at the age were
we can have great fun with them. we bought a nanda rapotor nitro truck but it was to much hassel traveling to get the nitro
so we bought a 1/5 scale petrol hummer the ShengQi .now as i done with the raptor i want to up grade the pastic bits for ali bits .
i,ve got a mate makeing me a ali roll cage and a few other wee bits but he can,t do them all so i want to know
what cars,truck r compatable with these and were can i get the up grade,s
thanks for your help
atb steven
atb steven
RE: what parts can i use
Basically you have a copy of a copy alot of parts will fit from Smartech Traveller & F150, Duratrax Firehammer, Carson Attack & Comanche and also FG Modellsport Marder and MT
ON, CANADA
I bought the same truck off ebay. Duratrax Firehammer MT parts will fit the trunk no problems. You can use FG parts but some are a little different. The spur gear and clutch pinion gear are a different number of tooth for the pair. I have put on the small fg aluminum engine mount. I have also used the aluminum front steering arms. You can use the FG spur gear and pinion if you also change the gear plate at the same time. The center to center postion of the shaft is diffenent on the FG one. Duratrax makes a better fuel tank that they just release for the firehammer MT. I put it in and it doesn't leak gas like the original ones.
http://rcinnovations.co.nz/shop/cata...hp?cPath=37_44
http://powerslideracing.com.au/index...acturers_id=55
thanks for the reply,s lads as i said i,m wanting to replave the old crapy
plastic bits for ali so this will help me alot
davido666 have u got any pics off youor truck and the mods u have done
would love to see it .
ON, CANADA
I am still running a plastic spur gear carrier so I have a weak spot that will give without destroying the drive train. I picked up the metal spur gears from Daves DDM for the firehammer. I shows he doesn't have any in stock now. I have been running them for a while and they still look like new. They are CAT5 gears.
thanks again mate i,m hopeing to start the modding as soon as i get my roll cage back from my mate . he,s looking
into machineing me one up . think this is going to be a long and fun project .
