Vertigo diff spool locker 5B
i want to replace my stock 5b diff for a new one , either getting the ss alloy diff cases or this spool locker . I dont know anything about the vertigo diff spool locker other than it replaces the entire diff that the 5b comes in as stock , if anyone has one can you explain to me the difference that this diff will make , the price of this spool locker is pretty tempting for me to get its only $55 australian dollars .
Banned
RE: Vertigo diff spool locker 5B
A diff locker will basically make the rear transmission like a solid axle. Only consider one for loose surfaces like sand as they do stress dogbones no end. Infact if your on hard pack, street, grass or any other kind of high traction surface do not try to run one. Also your turning radius will be greatly increased so no tight turns for you.
The Vertigo unit is the $$$ approach to the job, alot of guys just fill their broken diffs with JBweld or something to lock them up and it works just the same - although this would increase the weight/rotating mass but its unlikely you'll really notice the difference.
WSE do a locker for half the price of the Vertigo one but requires a diff case such as an old unused plastic one to complete (basically just replaces the gears) - available here: http://www.davesmotors.com/s.nl/c.88...t.A/id.5581/.f
The VP one is only $52.50 from here
http://powerslideracing.com.au/index...roducts_id=587
Banned
oops my bad, missed the part that he was in Australia - carriage charges may make the WSE unit uneconomical. Still i'd consider some JBweld in the old diff before spending 55au, thats if a rear locker is even what he really wants.
ORIGINAL: splcrazy
for this setup im going to run a TS crankcase induction engine with stuffed crank and 36mm ESP raceported cylinder head and big TGN race pipe , i want to run this for the on road only ,so some say that my setup is going to make 6.25 + HP, do you think it will be too much power and destroy the diff locker and dogbone axles ? I might have to rebuild my stock diff with the SS alloy cases and be done with it , i think that it will be too much direct power if i run the locker, unless i take off slowly and gradually increase the speed , im basically dragging in straight lines up and down the road then turning it to go back the other way .
Banned
Well as long as your just doing straight drag runs, remember to corner at the end at low speed and that the turning circle won't be good then it should suit you needs just fine. As AC says you'll have less lost power on take off so that should work well for drag runs, just remember to run good dogbones as they will be under more strain since there is no give in the driveline.
BC, CANADA
Our suggestion for those using lockers is to take caution on high traction surfaces and be sure to throttle off at the point of landing. Most often those that damage dog bones are those who sit and do donuts or land off of jumps on throttle.
Our locker retails for $32.00 usd..
BC, CANADA
In the past 7 years that we have been making lockers for RC Vehicles we have discovered sitting doing continual donuts to the point of giddy can break dog bones..
Banned
ORIGINAL: vertigo performance
Like the other guy said, once you break traction with the ground the driveline is under very little torque load. We've all been at this game along time...
ORIGINAL: splcrazy
do you guys think that it's really nessesary to change out the plastic gearbox for the GH alloy gearbox ? lol i have to ask these questions because of the screwed economy and we need to double check if were we are spending the money on for parts if its really worth it lol, because im gonna rebuild the diff soon and just want to have everything ready while i have it all open .
BC, CANADA
There is nothing wrong with using the plastic gear box. If we felt a new gear box was needed in order to use the locker we wouldn't have made the lockers.
Banned
ORIGINAL: splcrazy
If you mean running a normal plastic diff then I think you should know the answer by now, the plastic diff case is worthless when used as HPI intends, get the alloy HPI SS one instead if you want to run a normal (unlocked) diff.
