1/4 scale suspension/shock
Hi guys sooner or later i will building up 1/4 scale car.some parts i have been collecting & buying.
The problem is since the weight of the car will be much more heavy than hpi baja,,
by using 4 baja rear shock to put onto 1/4 scale car rear shock tower,do u guys tink it can withstand the weight
of the 49cc engine? or will it make the car droop more lower?
if it was impossible to use 4 baja shock ,which n where can i get this kind of shock?
any link or webby or pic?
plz advise....
plz advise....
IN
RE: 1/4 scale suspension/shock
You can purchase automotive lift supports from http://www.autopartsbylou.com/ Then place it in a vice and use a punch to discharge the gas from the lower chamber. Then spot weld the hole. Then either weld/clamp on a lower and upper spring retainer. Then purchase a spring from the home depot for screen doors and cut it to length. I am building a 1/4 scale pro street Beretta and that's what I'm using.
Once you get on the site select the, Select Extended Length tab. They have them as small as 3.6''
