Nodd's Great Planes Spectra
Back in the '80s I used to fly the heck out of my wooden rudder/elevator Gentle Lady. Wonderful little glider, would launch her from a high-start. Most flights were only a couple of minutes but once in a while I'd hook a thermal & it was game on. Since then I've flown all manner of sailplanes & I still enjoy thermal duration. Recently I've had a yearning to return to my roots & fly an old wooden two channel. My buddy Roger had an old beat up Spectra collecting dust so offered me the airframe. Okay so its not a Gentle Lady & it is electric powered (no high-start) but close enough.
So anyway after looking the airframe over & doing some surfing online I've decided I'd like to make a few modifications before slapping some electronics in her. The following is a record of my adventures with this fun little glider.
And before you guys start in with the comments, which I welcome by the way... I should mention that I'm not at all worried about maximizing performance or optimising handeling. This project is purely for the fun of tinkering with an old airframe. While I welcome advice you should know I'm a stubborn SoB & will invariably end up doing things my way anyway. I have a pretty clear idea of what I'd like to do here & I think you'll like what I have planned. And if not, then you can tell me "told you so" when she falls out of the sky. Enjoy...
The Wing
First thing is to remove the patchwork of old covering. There had to be four or five different brands of covering on there, this wing has been repaired that many times. A heat-gun helps release the covering, comes right off...
Now I've heard lots about how the Spectra is prone to tip-stalling. Folks have had success taming this beast by simply adding sheeting to the outer panels.
Mine are in pretty bad shape. The trailing edge is all sorts of warped-n-chewed up & sheeting her is not going to be as simple as slapping some 1/16" on there. So I've decided to rebuild them. First order of business is to cut off the old outer wing panels...
And seeing as I'm rebuilding these wing panels I figure I may as well take this opportunity to have some fun & do a little modding. Using the stock airfoil shape I drafted a new longer set of wing panels...
The new design will increase the wing-span from six feet to eight. I also decided to try using half-ribs instead of sheeting. Like sheeting these little riblets help maintain the airfoil shape between each main rib but at a fraction of the weight. No they're not as effective as sheeting but good enough for this old gal. So here's how the new wing panels might look...
And here's my template for cutting the ribs...
After printing my rip templates on regular 8½" x 11 paper I use contact cement to glue those to my balsa. Then after rough cutting the ribs on a scroll-saw I use a belt sander to finalize the shape. Not as slick as laser-cut but a lot faster than hand cutting with a knife...
I'll cut the notches for the spar tomorrow & then we can start assembling these...
My Feedback: (98)
You might want to throw some tabulator spars like the early CraftAir or Paragons, they work, but they look really nice too! I'd stick with the 2 meter wing since you ask, the longer wing will wallow on a 2M fuse and stab.
Because I'd like to keep the tip panels light I'll not be using sheeting so we need some way to keep the covering from sagging between the ribs. Saggy covering is no good for the airfoil, no doubt. You're not the first to suggest turbulator strips...
Turbulator Strips
Sheeting or turbulator strips are not the only solutions however. There's also the half-ribs option. Much like turbulator strips these also help maintain the airfoil by supporting the covering between the main ribs. For this sailplane I'll be using half-ribs, one between each full-rib...
Half Ribs
You're quite correct, slapping an eight foot wing on an airframe made for six will affect its handling. However I've run the numbers through my sailplane calculator & the horizontal stabilizer, while on the low end, does has sufficient area. The vertical stabilizer on the other hand will need to be enlarged a little. So with a slightly bigger rudder she should not wallow too badly.
Good points, both.
Turbulator Strips
Half Ribs
Good points, both.
Wing Assembly
I printed my CAD work on 8½" x 11" paper, taped the sheets together & we have plans...
Started gluing the structure together...
This will have to do for the day...
My Feedback: (98)
Looks good, your typical well thought out clean work. Yesterday I was just thinking of what you going to be building this time.I looked you up I couldn't find any new projects. Love your Gullwing electric sailplane.
What airfoil did you chose? You say stock, but do you know what they used? Did you know that the AG-34 to AG38 where design specifically to counter the sag between ribs?
I saw some speed props that kind-of went the other way though, they use nobs on the leading edge to copy Gray whale flukes which have them for lower drag. I had been thinking of building a wing, then rapping each rib with some CF tow I have before covering to get a rise at each rib, the thing that is against doing that is it will look as though I'm a worst builder than I am.
The Great Planes Spectra uses the Selig 3010 airfoil. Here's the website on the kit:
http://www.electrifly.com/largeelectrics/gpma0540.html
Once you get it done, we know you'll love it!
NY
Chris,
Neat winter building project. As a suggestion, you might want to calculate the horizontal tail (stab) area with respect to the original wing area and determine its percentage. Then consider enlarging the stab area to the same percentage as the elongated wing. The vertical (fin) area should also be increased but you can probably achieve this with a simple dorsal addition to the existing fin. The aerodyam experts can probably chime in on these mods also. You'll enjoy flying this modded Spectra once winter abates here in the northeast.
Rgds,
Art ARRO
Rgds,
Art ARRO
Thanks Art. As I mentioned earlier (post #4) I've run my modifications through a tried & trusted sailplane calculator spreadsheet & the stock horizontal stabilizer is of sufficient area to cope with the larger wing. The software did recommend enlarging the vertical stabilizer however which I am planning to do.
Increasing the size of a tail by increasing the span often gives a more efficient tail. Same idea as higher aspect ratio wings..........
Just a thought...
True Mr Rock. There's not much point to a larger wing if any benefits are lost because the tail is working too hard. I do not believe that's the case here however. These old two channel gliders have bloody huge tails to begin with. The horizontal tail is within the comfort range specified by the spreadsheet. If it was outside of that I'd definitely be making changes.
Although I'm modifying the wing to some extent, I'm trying very hard to resist the urge to rebuild the entire airframe which is something I could easily get carried away with doing. Building something completely new by replacing parts one by one is not my goal. Better to just scratch build something in that case (which I've done on occasion). I'd like to keep this mostly Spectra. I'm confident she'll fly fine as outlined & as I stated in post #1, this project is not about maximizing performance. I just want to have fun personalizing this old gal & get her in the air.
If it's not too late you might consider the half ribs extending a little past the spar. The biggest source of problems with airflow separation on many of these wings is the sudden straight line dip at mid rib right at the point of maximum thickness occurs. Namely the spar. This is the reason for Mark Drela's Allegro Lite having the top sheeting extend back to around 50 to 55% of the chord. Doing the same with the half ribs on your wing would produce some of the same gain.
I have to agree that the wing will now be a little too long to go with the fuselage. You'll likely find that some of the Spirit's good manners have left for Florida. It's not only a case of enough damping. There's other issues with the tail controls not having a long enough lever arm to work with on the new longer wings. Sure, it'll still fly in a stable manner and all that. But I suspect you're creating enough "features" in the handling that the graceful balance of the controls found on that old Gentle Lady might not be there any longer.
I had a GL back when as well. What a graceful and yet playful model it was. As you say the controls were excellently harmonized and there wasn't a bad trait to be found other than not wanting to fly fast. On calm to mild days it was a delight to fly. And you know.... You do realize that with all the work you're doing you could easily BUILD a GL from SCRATCH, right?
At any rate we're not going to sway the sort of man that can build a J3 glider and still retain secure in his manliness..... So I'll just wish you "Bonne Charpente"
If it's not too late you might consider the half ribs extending a little past the spar. The biggest source of problems with airflow separation on many of these wings is the sudden straight line dip at mid rib right at the point of maximum thickness occurs. Namely the spar. This is the reason for Mark Drela's Allegro Lite having the top sheeting extend back to around 50 to 55% of the chord. Doing the same with the half ribs on your wing would produce some of the same gain...
Now granted this is a flying-wing design but it does kinda illustrate that a tail doesn't have to be four feet behind the wing to be effective. The rudder on this was bloody huge though. No ailerons, this was a polyhedral rudder/elevator design. Sure wish I could remember its name, awesome sailplane though.
Anyway I don't want to spend a whole lot of time defending what I'm doing. As I said in my opening post, I have a pretty clear idea of what I want to do here.
Warning: The following may not be what you would have done.
My Feedback: (98)
Windlord, but the tips are different than the plans. You just couldn't help yourself even then. : )
I have a set of plans that I blew up to 200%. I built the fuse, but never finished the wing.
I ...
Hogwash. Spending a couple of days slapping together a pair of wing panels is NOT anywhere near as much work as scratch building an entire airframe, even a kit.
As for going on the defensive... Please don't consider unrequested advice as anything more than what most of it is: musings and such dredged up by your very entertaining projects Very often much of the advice is intended for the modelers attracted by your threads. Consider it more as incidental detail intended to enlarge your presentation.
BTW, when I was churning out all those wings I made up a couple with much greater than original wingspan, just to see what there was to learn. Near as I could tell, the test mule never showed symptoms of anything suggesting too small a vertical tail when the longer wingspan wings were strapped on. And there was no indication the horizontal tail might have insufficient power. What did show up was a suggestion of hunting when cruising. And there never was a clear indication of enhanced climb in thermals. I expected to create a better "soarer" and saw something akin to the opposite. In fact, on marginal days I was pretty sure the longer wings were a penalty. I never did build a larger tailed version of the models to see what they would show.
Your unique threads are some of the most enjoyable on the internet, and most certainly are going to kick a lot of glider guys awake and that's going to generate thoughts beyond yours. Don't spend any time defending. Heck, everybody learns from your successes and mistakes, and you obviously have no problem describing both.
A 200 percent version? !!! That would have been something. WOW
My Feedback: (98)
Yeah I hear ya but you get enough folks speculating all this stuff about your design (mostly negative stuff I should add) you kinda feel obligated to explain your reasoning. It's fine, it's just off-putting is all. Anyway here's some more wacky Nodd thinking for you all to chew on...
Sheer-Webs
I swear I'm not doing this just to make you guys crazy. Yes the grain in my sheer-webs is NOT vertical *shudder*. I've been over this in my other build logs so not really looking forward to revisiting it here. In a nutshell though, I've discovered grain direction is not as critical as one might think (please feel free to read up on the subject & form your own opinion, fascinating stuff). I do it this way simply because it's easier.
These outer wing panels are tapered so the sheer-webs are not all the same height. So to simplify production I cut a tapered strip of balsa based on the height of the spars...
I then cut each sheer-web to length...
Glue it in place & ta-da! it's the correct height...
I then took a closer look at the sheer-webbing in the wing center section & was horrified to find the webbing missing from these four bays. Now granted this wing has been repaired a gazillion times but as far as I can tell, there's no sign that sheer-webs were ever installed in these four bays. Very odd, I wonder what the story behind that was? Ran out of wood maybe? Geesh!...
Anyway I added sheer-webs to these missing bays (used vertical grain this time to match the existing webbing).
Half-Ribs
With the sheer-webs installed on both sides of the spar it was time to install my nifty little ribblets. I've always wanted to give these a try, liking the look of this...
Sheer-Webs
Half-Ribs
Windlord? Close but not quite. It's a WindFREAK. My fuzzy memory says it was a Roger Simpson design. It appeared in RCM way, way back in the mid 80's as I recall. A flying buddy of mine built one.
A case in point example of flying traits that goes with DaRock's story. About the same time as my buddy built the Windfreak I did an RO-8. It flew well but it had some odd features. Such as when in a thermal if I slowed it down a hair too much it would try to level the wings and fly out of the thermal. I just chalked it up to being how it was. Fast forward about 3 or 4 years and when I wanted to do my first electric powered sailplane I simply built a new fuselage for the wings and tail from the RO-8. By that time I realized that these traits of the model's handling were due to a lack of stabilizing authority. Not that it was unstable. Just that the size and leverage of the tail was not able to properly handle the forces at all flying speeds between stalling and lawn darting. So I made the tail about 2.5 inches longer and even reduced the size of the vertical slightly to make up for the added length. The new electric version with the longer tail was and still is a total dream to fly. The slow speed thermaling issues and sometimes sluggish reaction to rudder inputs went away totally. The electric version flies with the same snappiness and positive reactions to inputs as the Gentle Lady. Just while flying a little faster.
Since it appears that you're rebuilding the wing on this model as well as making a new wing you'll be in a good position to see if this occurs in this case.
But by golly, it's fun so far, ain't it.
Shear web grain direction works great either direction. Early magazine articles often argued the two directions. Bottom line is both beat none all hollow (pun intended).
Nodd, your pictures are quite a stimulus this time of year for some of us to get off our...... etc. Something exciting about a structure pinned out with the glue drying. Jeez, can almost smell the balsa.
Anyway getting way off topic... back to the Spectra, back to the workbench Chris...
ON, CANADA
1 Post
FWIW, here's what I did with my Spectra.
Sheeted outer wings with 1/32 balsa. Enlarged rudder by 1/3
Changed to 2217 low kv outrunner and 3s 2200 lipo.
Need that bigger lipo for balance anyway.
The motor & lipo change cut 20 ounces from weight making it one of the best flying 2 m woodys IMO.
Bo
PS: I really believe shear webs should have vertical grain to maximize strength.
Bo
