Go Back  RCU Forums > RC Airplanes > RC Gliders, Sailplanes and Slope Soaring
Reload this Page >
Foam wing bagging - warping wingtip edges
RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Old 05-28-2020, 12:51 AM
michajas
Default Foam wing bagging - warping wingtip edges
Hi,
I've started to experiment with vacuum bagging wings and it works great. One issue that I have is that when tip of the wing is rounded and tapered to the tip, the mylar that is covering the top and bottom starts to wrinkle on the rounded part of leading edge
This leaves me with uneven surface (very uneven) on the wing tips. I'm trying with to overcome this issue but maybe some of you more experienced people can give me some hint?
I'm using 0.25mm thick mylar sheet (maybe to thick?).
I'm bagging the wing (for now only the part of it for testing) without any surrounding molds (as I'm sanding foam, not wire cutting).
Thanks a lot for any advice
Old 06-16-2020, 01:15 AM
JohnMac
JohnMac's Avatar
Originally Posted by michajas View Post
Hi,
What I used to do was make the core a few inches longer than needed and then cut it down to size after wards. The other thing to try is make a wide, hard balsa or ply root and tip rib to stop it over compressing around the ends.Again cut them off after bagging.
John
