EPP Covering
Has anyone tried SIG STIX IT on epp foam instead of using 3M 77? I did a test on some epp and it held very well. It was much more secure than tape or heat shrink coverings. The only draw back I can see is that it would be very difficult to remove the covering when you wanted to recover the plane. The covering would require reheating as it was peeled away
