Towline help please
Towline help please
I've just started aerotowing and am just using about 100 foot of nylon string for the tow rope right now. The glider I'm flying is a 157" DG-300 and the tow plane is a Robin Hood 99. What is the best stuff to use for a tow line and how long, bungee or not. Thanks, Jeff
FL
lookee here
Check this out for a lot of info;
http://www.soaringissa.org/aerotowsheet1.htm.old
Folks like to use 1/4 thick line. Not for strength, but rather visibility.
FL
Towline help please
I tow a scale Waco glider behind a ziroli C-47, see pics at www.sarasota.com under Air Fair 2002, we use 150 feet of yellow string, with 18 inches of bungie to absorb shock.I wouldn't recomend 1/4 inch line because of weight You can attach a piece of bright ribbon to each end for visibility.I hope you have a release on the tow plane as well.
