Easy-build balsa sailplane.
Hi there,
Does anyone know where can I get good CAD drawings of an easy to build sailplane, I will be very obliged to that person.
Thanks in advance.
Thanks in advance.
RE: Easy-build balsa sailplane.
Welcome to RC Universe Doc!
There's not a lot of sailplane plans available for download but there are a couple. I'm sorry but I don't have the direct link to them saved but I'm pretty sure you'll find them on one of the links [link=http://www.rcuniverse.com/forum/Links_to_free_plans/m_1563599/tm.htm]IN THIS THREAD[/link] . If that doesn't work then try the following word combinations in Google....
free model airplane plans
model plans download
glider plans download
It's been a while but those worked well for me. If you find a new site that is not linked in that thread noted above please add a reply with the link to it.
A lot of the plans you will come across will require CAD or a .dxf / .dwg file viewer.
Good luck.
Good luck.
most supply free plans for a variety of models.
www.nationalbalsa.com
www.superiorbalsa.com
www.balsausa.com
www.balsausa.com
I think you guys should check where Doc Classic is located. If he's telling the truth about his locaton then I suspect it will be hard to get this stuff in Estonia. I gather that's why he's looking for something to download and build with his own supplies.
