Gerasis Fox 4m CG
Gerasis Fox 4m CG
I am ready to balance my Gerasis Fox 4m ws but I believe that I have received the 2m ws version instructions, In the manual it says 44mm behind the leading edge, but that can be! is just to near to the leading edge.
Any body out there with the correct CG or how to calculate it????
RM
RM
CA,
RE: Gerasis Fox 4m CG
Don't know the CG but you can use this webpage to figure it out.
http://inlandsloperebels.com/Calc/cgcalc.html
TFLG
TFLG
Thanks TFLG,
I made a mistake is 3m ws not 4m ws, the page for the calculations is very good, however the Fox do not have the wings swept back, on the contrary, they have a straight leading edge and reducing from the root to the tip, i will try to use a minus sing on the swept number to see if it works.
Regards,
RMM
Regards,
RMM
