Spektrum DX7
Spektrum DX7
While most of my flying is sports power and the Spektrum is ideal, does anyone know whether the DX7 will fly a full carbon sailplane? The small antennae of the receievers would be completely shielded inside the fuselage unlike at present with a 35mhz setup. Please ignore the fact that the DX7 is limited in scope for crow etc I'm only interested in whether the carbon fibre will kill the signal since the receivers are fully enclosed.
Hope you're having better weather than here in Yorkshire
kind regards
kind regards
TN
RE: Spektrum DX7
I have been flying the AR6000(DX6) in a 1.5M Epsilon on the slope. Only the antennae stick out from under the carbon canopy. Works great even under long range thermal conditions.
NY
RE: Spektrum DX7
ORIGINAL: MustangAce
Did you try that RX without sticking the wires out? The dual RX's of the DX7 would be harder/wierder to install that way because we're supposed to keep them separated and aligned 90 degrees apart.
I was hoping the carbon wouldn't shield the RX, but I guess it does if you took the trouble to mount yours with the wires outside. Where they taped to the side or just dangling out from under the canopy?
TN
RE: Spektrum DX7
The one pointing back toward the tail was completely taped. The other was taped at only half its length. The new DX7 isn't supposed to have any problems with interference I thought.
RE: Spektrum DX7
since I posted this I saw a post by the manufacturuer of the Xtremelink 2.4 system on the rcgroups forum who states that even fully enclosed in carbon a proper signal would be sent and received although there may be some slight loss of signal. I guess the only way is to carry out extensive range checks and see what happens! I know so little about this stuff and I'm not willing to risk the NYX without a warm blanket of reassurance
NY
RE: Spektrum DX7
ORIGINAL: aeajr
How are you setting up sailplane mixes on your DX7's. Especially how are you handling 4 servo wings, Crow, Camber, and other typical mixes since the DX7 doesn't have sailplane programming.
http://www.rcgroups.com/forums/showp...&postcount=833
http://www.rcgroups.com/forums/showp...49&postcount=6
RE: Spektrum DX7
Horizon hobby have a programming guide for the JR XP7202 fo9r the Hangar 9 Ultra Stick. The programming is essentially the same.
ORIGINAL: wind junkie
Here are a couple options. Neither is "perfect" but you can pick and choose what you like.
ORIGINAL: aeajr
RE: Spektrum DX7
All-carbon fuselages are a major problem with regular 72 mhz radios. In performance gliders the antenna is usually left inside the fuselage, in a tube, but this is not reliable with a carbon fuselage. Safest (but ugliest) is to take it out of the fuselage near the wing and tie it to the top of the fin. With the short Spektrum antennae, I would do a whole lot of range testing before putting the plane in the air.
