show us your gliders
#104
CO
RE: show us your gliders
Last Sunday I bought a plane called the Condor at a garage sale. I don't know any thing about it except that it is complete. I believe that it is a 3 meter glider. It has aluminum tubes that actuate the spoilers and ailerons. One of the linkage horns on the plane is broken. Can anyone tell me about this plane? I think it is about 35 years old. A copy of the plan would really be helpful. Is it possible to put a brushless outrunner motor on the plane?
Lynn
Lynn
#109
My Nietoperz SDZ glider, Horten III, an old Sig Wonder converted from glow to slope soarer, a Jart and it in a catching net, then a scratch built Hoffman type glider for slope soaring and can be towed (fitted with RC release hook) behind my tow plane.
#111
is the forth one a Katana? and if so is that scale? i didnt know they made a glider version, learned to fly on a katana
Also the picture of the large glider, not sure where that pic came from, but i like it.... also the other two, are of the same glider, one in construction and the other with, my sherpa for my hill adventures.... aka.... my father, hahha
#114
Magnum 12 Soarcraft 12 foot Wingspan - Own design Foam core wing, Carbon capped Spars. Ribbed dyhedrals. Flew great first flight.
I have 2 of them. The green Gray and White is mine.
The all Green is one My dad built in the 70's. It's Immaculate, I don't have the heart to fly it.
Hope you like them
Hope you like them
#116
New addition to the Old S'CooL hanger. A scratch build of my 60" Foiler using a carbon reinforcedArt Hobby Falcon fuselage. RG14 that can be loaded up to 15oz WL. Just a sport flyer ready for maiden once the weather turns around.
#117
TX, HUNGARY
Hey Folks,
This is my 5m ws,10kg PIK20 glider.It has a detachable motor mount, with a Hacker A50-16L motor 18x8 prop powered by 10 cells 4900 LIPO battery.I can aerotow it with my CARF Extra 330L and power it with the electric motor at the same time.I love it.
#118
CA
This us a 85.75in. wing for a 36.5in fuse. I was told to put spoilers on it but I have no idea how to set up the mechanism. Also, if spoilers were on the wing, they would probaly be right in front of the aelerions, which might make turning uncontrollable right when I need the plane level. Does anyone know if the spoilers were put right in front of the aelerions it would cause problems with turning?
#119
More than likely they would. Best to keep them inboard by at least one bay from the ailerons. I'd make them 2-3 bays wide at most on each side of the wing. (some people get into over-kill on their spoilers) From what I can see in the 2nd picture, the ailerons should be moved towards the tips by 2 bays. The closer they are to the body, the less effective they will be. That would also make room for spoilers to be added.
If you don't want to go to all the work of moving the ailerons, then make your spoilers 3 bays wide starting at the edge of your sheeting. That would be the quickest way to go.
What other controls are you planning on?
#123
Hi Guys
Here are a couple of PSS models that we are using in the UK at present:
The Fw190 and Me109 are GWS foamies and the Spit is a scratchbuilt all balsa model.
I am currently building a P-40, photos coming soon.
#124
ON, CANADA
Gunny
The plane you have is great. Do you work for Aviation Concepts? These are the people who presently kit this plane. The pictures come off there web page
Glenn
Glenn
