RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Combat Wing Tape
Old 07-17-2008 | 11:43 PM
Cashpoboy's Avatar
My Feedback: (7)
Default Combat Wing Tape
I am new to combat slope wings.
I recently purchased a 'Prairie Dog' which is like a Zagi or any other EPP slope combat wing.
What kind of tape do you use to cover the wings?
I understand that I will need strapping tape for strength. What brand and width do I need? Any cheap sources?
Also, I see that colored tapes are used to cover the final build? Same question. What kind, width, brand, thickness....etc?
Any low cost sources for these?
And finally I see that I will need tape for the hinges. Same questions with this too.
There are no building instructions with the kit. I spoke with Jack the kit manufacturer and he is working on an instruction sheet. It's not a problem as it appears very simple and there are online manuals for Zagis and other similar models that I can follow.
The tape issues are really what I need help with.
Thanks for any help.
Old 07-18-2008 | 12:06 AM
OzMo's Avatar
Default RE: Combat Wing Tape
pop over to the combat forum and ye shall find what ye seeks.....or this tape stuff is sticky business.
seriously the combat guys have this down pat
Old 07-18-2008 | 12:09 AM
Cashpoboy's Avatar
My Feedback: (7)
gracias
Old 07-18-2008 | 12:28 PM
There is a special kind of tape used in Drywall construction which is reinforced with filaments. It is transparent and about the same width and thickness of packing tape. Colored tape? Buy at Zagi. com...
Forgot to mention you can also buy the fiber tape at Zagi.
Old 07-18-2008 | 03:11 PM
My first Zagi I used the colored packing tape you find in Hobby Shops and on Trick RC website. Worked fine.
I recovered it using Ultracote for a cleaner finish and liked that more.
Old 07-18-2008 | 03:13 PM
btw,
if you try ultracote you need to be very careful with the heat applied, you can melt or even warp a wing relatively easy.
Old 07-18-2008 | 07:52 PM
Cashpoboy's Avatar
My Feedback: (7)
I just came across some info on U-line and Fastpack tape.
Have any of you tried these and if you did how did you like it?
Old 07-18-2008 | 09:48 PM
My first Zagi came with the Trick RC tapes and I have had very positive results with these, however, the fiber tape is not as good as the 3M one.
