RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Plank Slope Soarer
Old 02-15-2009, 10:15 AM
cpc625
Default Plank Slope Soarer
Back in the '70s there was a construction article for a glider called The Plank. I thought it was in RCM, but I have been unable to find any reference to this glider. Anyone remember this?
I believe there was also a follow-up called a Plank II.
Charlie
I found the info. I had the name wrong. It was "Little Plank". Now to find my copy of the magazine.
Old 02-15-2009, 02:22 PM
Tinkrerpilot
Default RE: Plank Slope Soarer
Since you found the the LITTLE PLANK 5 #492 5/72.
There is also the Standard Plank, STANDARD PLANK 5 #605 7/75.
http://www.rcmmagazine.com/store/sto...sQ8K3YrCY3p5V6
Have fun!!
tink
Old 02-15-2009, 02:35 PM
cpc625
Tinkrerpilot,
Thanks. I went to the attic, found my issues of May & June 72 RCM, with the Little Plank and Windfree, ran the scanner and am ready to plot.
It's back to the attic to get the July '75 issue of RCM.
I built one of the Little Planks back in '72 and had a ball. I still have the fuse but threw out the wing a few years ago because it had developed a very bad warp that I could never remove.
Thanks again
Charlie
P.S. The Standard Plank is in the scanner.
Old 02-16-2009, 01:37 AM
Tinkrerpilot
Very nice! Do a build for us and let us watch the progress as you go. Built one years ago. Had a blast with it. if only I had more time....................
will be watching, if ya do the build log.
Old 05-21-2009, 01:16 PM
Pilon_1
Pilon_1's Avatar
My uncle just completed his Little plank from RCM plans. He built one in the 70s powered by a Cox TD .051. it was crashed and the fiberglass fuselage he built was given away. I bought him a set of new Little Plank planes last year for Christmas. He just finished it and covered it like his original one. He built a new fiberglass fuselage to accommodate an electric motor. The wing was extended one rib bay width like the last one he built. Two Hitec servos were used instead of the mechanical mixer shown in the planes.
ID:	1203081   Click image for larger version
ID:	1203082   Click image for larger version
Old 10-08-2009, 12:26 PM
CRG
That's a sweet looking Plank. I just ordered the plans for it last week, going to build one to surprise my Dad when he comes to visit in April. When I was a kid I'd go to the slope with him and watch him fly his Plank and Gryphon, he loved them both. Got a Gryphon sub-kit too.
Old 10-08-2009, 02:13 PM
foodstick
foodstick's Avatar
It seems like only yesterday these kits /plans were out, and the local hobby shop had a klingberg wing on the shelf, heck they had two hundred kits on the shelf...
Old 10-09-2009, 02:59 AM
Tinkrerpilot
Pilon_1
Great looking model. ANymore information on the motor, battery, esc setup that you can tell us?
Uncle does great work. Really like the fiberglass fuselage. How about a flight report?
Lyle
Old 10-13-2009, 06:44 PM
Pilon_1
Pilon_1's Avatar
After a few flights getting the CG and trim set the Little Plank flew like his original one. The plane is very responsive and surprisingly aerodynamically clean, give yourself a long approach when landing. Power is supplied from a Grayson's GH2212-10 with an 8x6 APC pusher prop and a 3cell 1200 lipo. Even with the extra wingspan this thing literally flies out of your hand while launching. The plane seemed to come out on the tail heavy side and nose weight had to be added, the fiberglass fuselage moves the motor back adding to the problem of tail heavy. I think when I build min I am going to shorten the rear motor mount and actually run a little smaller motor to save weight.
Old 10-13-2009, 06:50 PM
CRG
Got my plans last week, and ordered wood today. Will be non-motorised, and will stick with the original span. Materials cost was about $35.
Old 10-13-2009, 07:41 PM
Pilon_1
Pilon_1's Avatar
The stock wooden fuselage was originally built to support the older servos and mechanical mixer for elevons. By moving the servos out in the wing the fuse can be narrowed allot to reduce drag. Our original fiberglass fuselage had no motormount and was fitted with a towline hook for our wench. There seems to be an almost never ending thermal a our new flying site. We were thermaling Slow Sticks last weekend!
Old 10-13-2009, 07:45 PM
CRG
Was debating whether or not to do that. Will only have a 1600mah pack and AR6200 in the fuselage, but am tempted to keep it original just for the sake of it. Will be a game-time decision...
Old 10-14-2009, 02:53 AM
Tinkrerpilot
Pilon_1
Thermaling Slow Sticks. Been there don that. Its a hoot. Sounds like you have a good flying site.
CRG,
Please do a build thread when you get ready. It has been awhile since mine and would be great to follow along.
Will be interesting to see what you decide to do on the fuselage. If you don't need all the extra room for the old style gear, thinking it would be a benefit to lose some of the extra weight in the long run. Matter of choice. Lets see which way you go.
Old 02-06-2010, 07:48 PM
CRG
Got started on the LP this week. So far have made a few small changes, nothing major. For some reason my rib template is a little longer than the plan, by maybe 3/16 inch or so. Must have happened when I copied the plan, I make a copy of the rib then stick that to a piece of thin ply to cut out the ribs. Won't make much difference except I'll have a tiny bit more wing area.
I decided to use all the same ribs, and cap strip the ribs that aren't sheeted. Used to build wings that way years ago and it seems odd to have just bare ribs under the covering. The trailing edge stock that came was the wrong size, so I mounted it flush to the upper surface of the rib and will add a trailing edge strip of 1/16 inch sheet. The strip will be a little narrower than the TE stock and the rib cap strip will continue over the TE piece a little. Servos will be in the wings, and I'll bolt the wing on. Also toying with some kind of plug-in system for the fin rather than gluing it on.
I ended up reducing the fuselage width by about 3/8 inch. Any more and it might start to look a little too tall, it's supposed to be round at the back of the nose block. Could have reduced the depth also but am trying to keep it looking somewhat original.
All the 1/16 inch balsa sheet I have on hand is too soft for wing sheeting so I have to order some before I can go much further.
ID:	1373264   Click image for larger version
ID:	1373265   Click image for larger version
ID:	1373266   Click image for larger version
ID:	1373267   Click image for larger version
ID:	1373268   Click image for larger version
ID:	1373269   Click image for larger version
ID:	1373270   Click image for larger version
ID:	1373272   Click image for larger version
Old 02-09-2010, 05:10 AM
Tinkrerpilot
Thought of this web site a little to late, since you already have the fuselage already built up. Would have saved some time.
Still psot it though for the other that mey venture into the Plank flying wings. The website is worth looking over. Look forthe one called The Board (Little Plank to us). Note the RCM sticer on the tail.
http://www.modellbau-steinhardt.de/
I know a few of the guys have oreder from here and te quality is pretty good for the most. They list what is available for the whole project.
Another site to cruise through too.
http://neckar-verlag.de/index.php?id...&tx_edshop_pi1[obj]=prod&tx_edshop_pi1[cmd]=detail&tx_edshop_pi1[uid]=144
Old 02-09-2010, 05:15 AM
Tinkrerpilot
CRG
Your build is looking great. Any problems noted other then the capstrips on the ribs?
Almost forgot how much balsa went into the making of the fuselage. I used a lot of laminated wood to gain some strength
when I built mine way back when.
Old 02-09-2010, 11:16 AM
CRG
No real problems, and the capstrip thing was just a change I decided to make, no issue with the design. Will be a couple of weeks before I get the wing sheeting, but I hope to have it finished before too long. Fuselage is about shaped, and ventral fin installed. I inset a thin strip of ply into the fin to strengthen it a little.
ID:	1375019   Click image for larger version
ID:	1375020   Click image for larger version
Old 02-12-2010, 12:59 PM
FLYBOY
FLYBOY's Avatar
I still have one floating around somewhere. they were fun on the slope. Haven't been able to do that for years. Will have to try it again.
Old 02-17-2010, 01:00 PM
soaredg
HeyGuys
Here's a picture of my original design Plank FW loosely modeled after Dave Jones 2M Raven. 100" span- 2Ch (rud & elev)- built up wood with 1/2" carbon tube spars-glass fuse-over 75 flights off a winch.
Ed
Old 02-17-2010, 06:57 PM
Tinkrerpilot
soaredg ,
Great looking model. I can see the slight variation in the model. I built a Raven back '73. Used the split rudder for a speed brake more then spoilers. Think if it was todays option, it would be the split rudder and spoilers in the wings. Should slow things real quick. Thanks for posting the picture.
Are the plans still available??
Lyle
Old 03-30-2010, 09:47 AM
CRG
Making some more Plank progress. Hoping to be done for my Dad when he gets here, which is less than two weeks. Am getting close.
Had to abandon my bolt-on wing plan, went with dowels and rubber bands. I am keeping the fin removable. Rather than use regular extensions between the wing and fuselage I mounted a 6-pin connector in the wing, it's flush to the lower skin.
Still have to glass and paint the fuse, and cover the fin and elevons.
ID:	1407804   Click image for larger version
ID:	1407805   Click image for larger version
ID:	1407806   Click image for larger version
ID:	1407807   Click image for larger version
ID:	1407808   Click image for larger version
ID:	1407809   Click image for larger version
ID:	1407810   Click image for larger version
Old 05-13-2010, 09:37 PM
skybill
Hi Guys,
Flying Planks!! Yahoo what fun! 'Brought back memories of my own "Plank" from back in the early 80's at Estancia Bluffs Costa mesa CA. Troops were taking old control line kits and "Bashing" them! Top flite "Flight streaks" and the like making 2ch. slope machines out of them. The Riley Wooten VooDoo made a really nice "Plank!!" 2ch. aile-elev and GO!! That thing would turn on a dime and give you 9cents change!! Flew the plane for a couple of years at Estancia and Back Bay until Larry White center punched it with John Raleighs' Shadow!! All I have left is the VooDoo logo from the wing and the twin rudders.
Blue skyz,
Bill Deli, (skybill) AMA-87838
Old 02-16-2013, 01:57 PM
Tspin
Tspin's Avatar
Im looking for the plans for the "Little Plank" glider, any help would be appreciated.
[edit]
I think I found the source
https://www.rcmplans.com/index.php?m...ort=20a&page=5
Old 02-16-2013, 11:45 PM
Tinkrerpilot
Yup! You got it.
Old 02-17-2013, 10:36 PM
BMatthews
BMatthews's Avatar
The RCM plans service is run by an older woman that is likely the widow of one of the old RCM staff. She gets the orders out but sometimes it takes a while. Be patient and give her a reminder if you don't see your order in a couple of months. But I gather you'll get the plans eventually.
