Graphite 2E from Vladimir's Models
Hi everybody!
Got myGraphite 2E crosstail made by Vladimir's Models in Ukraine. It's an electric version of Graphite 2 glider. The quality and craftsmanship is impeccable! Absolutely stunning! Glider is 100% built and requires only equipment installation. So, considering the price of $1,000US delivered - in my book it's much cheaper than Art Hobby's Vortex ($400) as Vortex requires a lot of building to finish the glider. Considering my lack of hi-end power experience I have a few questions regarding the power plant/prop/ESC etc. I used a power calculatorwith the following variables: Model weight: 2.5Kg Battery: 4000mAh 3S ESC: Max power 60A Motor: Hacker A30-18M V2 with 6.7:1 gearbox Prop: Aeronaut 17x11 no yoke twist and it showed me Static thrust: 2,387 Kg Prop stall thrust: 1,363 Kg I know, motor is an outrunner, not the inrunner but considering it draws 1.9A idle current instead of 3+A on recommended inrunners I am gaining some flight time there while enough power is available according to calculator. My questions are: Motor's operating current is 50A and peak current is 70A. How do I choose ESC? By peak current or operating current? What's the high-end dependable ESCs out there? Do I use built-in BEC or should I opt to separate BEC? I have Aurora 9 radio with Optima 7 Rx that will let me use separate BEC unit. I plan on using MKS DS65K for rudder and elevator, KST DS135MG for ailerons and KST DS125 for flaps. Also I am researching idea of placing Rx in the wing and run quick connector for tail servos and power connector instead of ailerons and flaps since wing is hollow and has plenty of space there. I will post some pictures of the progress soon. Thanks for all the help! Mark. |
RE: Graphite 2E from Vladimir's Models
1 Attachment(s)
just a couple of pics:
1 Attachment(s)
Just a few more pictures before servos and motor arrives.
1 Attachment(s)
Hi longsoar, I really love flying my Graphite and have just re-powered it with some Lipo batteries. The first outing with them turned out bad as the battery I had down the field dropped a cell so it was quite a short flight.
I have about 50 flights on mine with no incidence. I'll get some specs for you. Cheers, Brad Hmmm, just re-read your specs and you have the 2m. Sorry. |
Hi Brad!<div>Big hello to Australia!</div><div>Nope, I have 3.1 meter version.</div><div>2 meter is Mini-Graphite and mine is Graphite 2E.
<div>Thanks for the post. Your Graphite looks Hotttt!</div></div><div>Mark</div> |
Oh yes Mark I should have realised you didn't say "Mini".
Here is a thread of mine with a gear list and a couple of flight reports. http://www.rcuniverse.com/forum/m_58...tm.htm#9093516 As you will see I am of no competition standard just an enthusiastic sport flyer. Enjoy putting it together and flying some nice peaceful flights. Ask any questions about the build if you like. Cheers, Brad |
1 Attachment(s)
Just received 2 KST DS135MG and 2 KST DS125MG servos (total 4 servos) for US$99.48 delivered from Aloft Hobbies.
Servos are $24 each. Servos for flaps and ailerons. Two MKS DS65K servos coming next week from Soaring USA ($126 delivered) for the rudder and elevator. Also HackerB40-12S with 4.4:1 gearbox coming tomorrow. All of the above will keep me busy installing hardware and I'll be posting images as they come. <br type="_moz" /> |
1 Attachment(s)
Here's the pictures of MKS 65K servos and Hacker B40 12S w/4.4:1 gearbox.
Those servos fit nicely in a Graphite tail and offer plenty of room for installation. After checking a slop on MSK servos and KST servos I think I'll get MKS DS6125 mini for ailerons and DS6125 for flaps. Price difference is almost twice but this is not a $200 glider either. The good part is that MKS and KST servos are identical in size, so I can install aluminum servo mounts with extra bearing from Windrider. <h1 style="padding: 0px; margin: 0px; font-size: 16px; font-family: Arial, Helvetica, sans-serif; color: rgb(0, 94, 162); background-color: rgb(235, 247, 254); "></h1> |
Longsoar - I hate to rain on anyone's parade, but I think you're going to find the model underpowered with a B40-S motor. The 'correct' motor for the Graphite would be a B50-L with perhaps a 4S battery. Sure, it'll fly with the motor you have, but the climb's going to be rather anaemic.
Yeap Gtarling,<div>I am aware of that. It will not produce 5 kilo of thrust. It will only produce 1.6kg of static thrust with 13x8 prop for 2.5kg glider.</div><div>In my book (I am not competing) it'll be enough to climb at about 2 m/sec.</div><div>But hey, thanks for noticing!</div><div>
</div> |
Longsoar - In that case, I hope it meets your expectations.
<span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">Gtarling,</span><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">Correct me if I am wrong..</span></div><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">By using this motor I will get 1.47A drain per 8.4V when not using a motor instead of 3-3.5A on B50-L</span></div><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">It'll give me more airtime.</span></div><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">As a trade-off I will not get straight-up climbing but rather 30-40 degree climb angle. Instead of climbing for 10-15 seconds it'll take me close to 30.</span></div><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">I am ready for a trade like that.</span></div><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">Also, if later I feel I need a bigger motor - I can always upgrade.</span></div><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">What do you think?</span></div><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">cheers</span></div>
Longsoar - sorry, I don't understand your '1.47A drain per 8.4V' statement. What people often fail to realise is that to get a glider of a certain weight to a certain height takes a set amount of energy - simple physics. Now, you can either deliver that energy over a short period or a longer period, but the result will be exactly the same. Until you've flown a large glider with an anaemic climb rate, you're not going to realise the importance of getting a high rate of climb to punch through the lower level turbulence as fast as possible. Now, you don't need a 'rocket - like' climb to achieve this, but you really want to have a climb angle of around 60 to 70 degrees if you can. From Motocalc, your B40-12S is going to be producing around 430 Watts on your 12 x 8 prop with a 3S 3000mAh Lipo pack. Apart from the fact that a 12" prop is on the small side for a model of this size, this is getting close to the 500W/15s limit for that motor, so if you have a climb exceeding 15 seconds duration, you also stand to be running into motor heating problems. My advice would be to return the B40 if you can and get either a B50-S or B50-L with the 3.7:1 gearbox and a 14" or 15" prop. If you're really stuck with the B40-12S, then give it a try by all means, but I feel you'll soon be thirsting for some more power!
<span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">Gtarling, thanks for your input!</span><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">well, as I understand according to Hacker specs motor will drain 1.47A when it's not spinning as an idle drain.</span></div><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">For B50* this rate is anywhere from 3 to 3.5A per every 8.4V depending on a model. I hope I did not miss anything here.</span></div><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">Also, I'll be using 13x8 prop and according to a calculations it'll produce around 1.6kilo of thrust which is a fair amount for the 2.5 kilo glider. Cruising calculated speed is about 92 km/H (close to 25m/s) - more than fair for that glider.</span></div><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">I assume the climb angle will be about 40-50 degrees at a speed of about 55 km/H. Angle will be less at higher speed.</span></div><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">
</span></div><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">I remember in 70' I saw an article with picture in one of the magazines where real open class glass ship (glider) took off on it's own from the paved runway on six 10cc (around 1HP each) RC engines.</span></div><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); "> </span></div><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">Yeah, I agree, underpower sucks! But I'll try this setup and if anything - I'll upgrade.</span></div><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">Thanks again for your input!</span></div><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">cheers</span></div> |
Longsoar - the figures you're quoting for the motors are what's known as 'no load current' - sometimes shown as Io. This simply shows how much current the motor pulls with no load and is only one of the factors which help determine how 'hot' a motor is. The B50 has a higher figure than the B40 because it's a larger motor with lower resistance that can deliver more power. Motocalc is showing your setup as developing around 80 ounces of STATIC thrust, which ought to fly it OK, but don't forget that the model ISN'T static, so that figure may or may not be indicative of performance. Do let us know about the performance once you have it flying.
<div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">Gtarling,</span></div><div><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">Yes, I did check the resistance on both of Hacker motors and here is the data:</span></div><div>B40 12S w/4.4:1 Resistance: 0.0213 Ohm</div><div>B50 12S w/ 6.7:1 Resistance: 0.0129 Ohm</div><div>B40 motor has more resistance, both 12 turns short motors and B50 has 2.39A idle current compared to 1.47A B40 has.</div><div>My calculations show 1.6Kg (about 50 ounces) thrust while pulling 28A, with max 40Amps it will be probably around 2Kg.</div><div>So, even at 28A glider should have enough thrust doing 50 km/H (way above stalling speed). At least I feel comfortable with those numbers.</div><div>I definitely will post my report on performance results. It's almost a week wait until all parts arrive (some of them from Taiwan) so I can put everything together.</div><div>I also really re-thinking my servo KST choice and a lean towards ordering MKS servos for flaps and ailerons. KST can be used on some less expensive projects.</div><div>Thanks for your conversation and notes!</div><div>cheers</div><div>Mark</div><div>
</div> |
1 Attachment(s)
Finally got a powerset together - motor mouting screws (which were not included initially) and a HyperSpinner 38/4/0 by Vladimir's Model. Painted spinner in white.
1 Attachment(s)
Today I have finished the silicon mold and made a copy of MKS DS65K servo to create a servo frame for it. Silicone used is Rebound 40 by SmoothON.
Silicone would not stick to anything. It makes it easy to work with. I just poored fiberglass resin into the mold. |
Seems like a lot of trouble to me. [link=http://www.hyperflight.co.uk/products.asp?code=DS65K%2DSERVO%2DFRAME&name=hyper flight-servo-frames-for-mks-ds65k-servos-pair]Servo Mount[/link]
1 Attachment(s)
<span style="font-family: Arial; ">Gtarling, could be a lot of trouble but beats ordering from UK to US delivery time and those general servo frames make installation kinda cumbersome.
</span> |
1 Attachment(s)
<div>As chance would have it - I ordered servo frames from Hong-Kong and they arrived with wrong bearing screws. I have KST servos and screws thread included in a kit were for MKS servos. So I ordered 2 x MKS DS6125 for flaps and 2 x DS6125 mini for ailerons ($303 delivered).</div><div>Chinese servo frames have a huge slope in bearing. I thought I can make a better frames with external ball bearing. Made a mold and here we have it.</div><div>My frames altogether lighter than Chinese ones and offer a bigger gripping surface for epoxy. No slope at all in ball bearings (ordered 3x7x3mm ball bearings online $1 a piece). Carbon fiber I had and epoxy is not an issue at all.</div><div>Anchors for mounting 4-40 screws were molded-in.</div><div>I am waiting on MKS servos to verify they will fit perfectly before gluing frames in place.</div><div></div>
1 Attachment(s)
Finished tail section with wiring and controls done. Wiring is covered, connectors are covered above the rudder servo.
ORIGINAL: longsoar Finished tail section with wiring and controls done. Wiring is covered, connectors are covered above the rudder servo. Cheers, Brad |
Hey Brad!<div>Yeah, kinda jammed in a tail section. That's the reason I used wire guides to make sure they wont interfere with controls.</div><div>How's you flying going?</div><div>cheers,</div><div>Mark</div><div>
</div> |
Looking forward to a flight report.
I have the Graphite 3.4M Dbox ( built up wing, not molded) and it is a great thermal soaring machine. |
| All times are GMT -8. The time now is 12:13 PM. |
