Need help with an Mcx on a DX7
NJ
I've been able to bind my Mcx to my DX7, but either way I do it (acro or heli), It still doesn't work correctly. In either case the elevator stick only works one swash plate servo and the aileron stick only works the other servo. Anyone run into this?
RE: Need help with an Mcx on a DX7
That is correct. The mcx is not a ccpm helicopter and is only a 2 channel swash and only one servo at a time will move. Simply set in the transmitter as an airplane and be sure the servos go the correct direction.
Jim
Jim
