Go Back  RCU Forums > RC Helicopters > RC Helicopter Beginners Forum
 basic rc helicopter question >
RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
Old 11-22-2010 | 06:07 PM
Default basic rc helicopter question
hi all,
do all rc helicopter rotors spin in the same direction?
thanks,
bart
Old 11-22-2010 | 06:44 PM
BarracudaHockey's Avatar
Default RE: basic rc helicopter question
Basic answer: No
But....given that engines rotate counter clockwise, slap on a pinion on fhe output shaft, then a big counter gear, its pretty obvious why most of them are clockwise rotation.
There's a few that use belt drives or the like that rotate the other direction.
Since most electrics are based on their nitro brothers or use the simple pinion/counter arrangement, many of them have a right hand main rotor as well.
For a scale application I took a Logo 10, swapped two motor wires, turned the blades and paddles over, and turned over the autorotation bearing, and it flew just fine (though it was weird for a while seeing it lean right instead of left)
Old 11-22-2010 | 08:00 PM
thanks for the reply. where's a good place to shop for rotor blades? i'm doing a little experimenting and would like to find some flat bottomed main rotor blades in the 10 to 12" range. if i could find them to rotate in both directions that would be ideal.
thanks,
bart
Old 11-22-2010 | 09:38 PM
Good luck with that quest. Flat bottom blades in that size will be hard enough to find, left hand rotation flat bottom blades in that size would be like looking for hens teeth.
Old 11-23-2010 | 07:45 AM
andy
i can cut and balance longer blades but i'm having trouble finding good places to look. where's a good place to shop? tower? helidirect?
thanks,
bart
Old 11-23-2010 | 09:34 AM
Try this place. http://www.heli-world.com/
Or http://www.ronlund.com
Old 11-23-2010 | 09:41 AM
thanks. i'll check them out.
gobble gobble
bart
