blackhawk 450 newbie
I have a blackhawk 450 and need to set my pitch. Im not planning on doing any 3d. My question is< when i set it up< do I want 0 degrees at mid stick in normal mode, or 0 degrees at bottom stick? Thank you very much
RE: blackhawk 450 newbie
It is always best to set the pitch at 0 degrees at mid stick for all flight modes. Then you can set the pitch curve in normal mode so you have about -2 degrees at low stick. You should generally have a couple degrees of negative pitch at low stick so that if you get some strong wind that causes the helicopter to 'balloon' into the air, you can pull it back down.
