6 Ch Simulator Software
I need to order a 6-channel simulator kit (for my 6ch. e-sky heli).However, I'm havingdifficulty findind a 6 ch. kit for the e-sky.I'm assuming that any 6ch. simulator kit would work, but wanted to be sure before Ibought one.
You may be able to use the TX that came with the e-sky heli to run with a simulator. There are several free sims you can download like FMS and there is another strictly for helis called heli sim rc that seems to be good too. I'm a noob to helis too so there may be others that more folks would recommend.
Look on the back of your tx and see if there is a port or jack marked either trainer or simulator. That port can be hooked to your pc with the appropriate cable and then used to control some of the free sims. I have also heard good things about clearview and it is reasonable ($40 I think).
Hope this helps,
Jim
Hope this helps,
Jim
Looks like Ican use the actual controller. I forgot about that. I just need to find where to get the cable. Found a website selling it in the UK, but I'm in the US. I'll look around some more. Can you recommend a vendor?
