Phoenix Simulator Software Question
Hi: My wife bought me a Blitz RC Tornado 6 ch helicopter for me for Christmas. I have only played around with the small indoor RC choppers in the past so this is totally out of my league. To learn how to fly, I purchased Phoenix v3 with the Spektrum radio. I have it set up for the most part, I think, however, I can't seem to hover. The throttle is so sensitive, the second I give it enough throttle to lift off the ground, the chopper rockets into space. There seems to be no inbetween between the blades not rotating and them going full bore out of control. Does anyone know what I'm not doing correctly? Thanks
RE: Phoenix Simulator Software Question
Sorry, this will show how new I am, but what do you mean by TX? I calibrated the channels. I don't know if I did it correctly, but it seems to work as it should, except the throttle, as mentioned, is so drastic.
sounds like you may be in "idle up" (sometimes regarded as Stunt Mode1 and/or Stunt Mode 2)mode right from the beginning and you should be in "regular" flight mode.
In "Idle Up"...your motor speed is (or should be) constant and the only thing that changes is pitch. This allows a CP heli to fly inverted as 0 (middle) stick you have 0 pitch. below mid stick would give you negative pitch to fly inverted and positive stick...you guessed it, positive pitch. Since you are using your throttle gimble to change pitch...throttle has to stay constant.
In "regular mode" you have a throttle curve that starts out at 0 throttle at full negaive gimble position and goes all the way to around 80% of throttle at the fully positive position...changing throttle speed (head speed) and pitch along the way.
So...based on that lengthy explanation...it very well could be that your SIM is starting up with idle up enabled. I dont know how to tell you to check for that as I dont own, nor have ever used Phoenix. But it would be a place to start looking. If thats not it...Im afraid you will have to wait for somoene to chime in that actually owns or uses Phoenix SIM.
goodluck
goodluck
ORIGINAL: Mark81
Rafael
