RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
New to flybarless
Old 05-27-2015 | 07:27 PM
Default New to flybarless
I have finally switched from fixed pitch to flybarless. Doing OK. Nothing fancy, no crashes. I do have a couple of questions. I'm using a Devo 7 Tx that came with the heli and the manual talks about pitch curves and throttle curves. I seem to understand throttle curves (currently P1-INH, P2-INH, P3-INH, P4-INH, P5 100% and from what I understand this makes the throttle perform at a linear rate 0% to 100%) has been programmed into the Tx but I am totally clueless about pitch curves. The manual provided no help what-so-ever. Any help would be greatly appreciated. The heli is a 450 size. I am looking for some beginner settings.
Old 05-28-2015 | 02:00 PM
You will find that a flat throttle surve will fly it much better as it will keep your rotor speed more constant.. For starting, I would set the "Normal" curve as 0/90/90/90/90nd when in the air go to the idle up with a curve of 100 at ALL points.
Old 06-02-2015 | 03:08 PM
Rotordoc...I am totally confused trying to figure out those settings....maybe I am lost....you are talking about pitch curves? 100/100/100/100/100 at all points in idle up? 0/90/90/90/90 in normal mode? Pitch curves?
Old 06-02-2015 | 04:56 PM
I am sorry, my bad, I was referring to the points on your throttle curve.
If you do not have a pitch guage, then it is hard to help. But to start you may want a normal pitch curve (where you would never be flying inverted) with 0 degrees of pitch at the 50% mid stick position, maybe a -4 degrees at bottom stick, -2 degrees at the 1/4 stick position, and +4 at the 3/4 stick position and +12 degrees at top stick positions. For more aerobatic flying in an idle up position you may want a pitch curve with -12/-4/0/+4/+12
All of these pitch setting will vary relative to the type of flying you are doing, the heli your are flying and the power that your motor/battery combination gives you.
Old 06-03-2015 | 09:33 AM
Thanks for the clarification...I kind of figured you were talking about throttle curves. Hopefully bignuggets sees your reply and reads up pitch curves. I know when you first begin you really need to understand how throttle and pitch work together and how you fly does make a difference on how you set things up.
