Rc Helicopter to lift 200g/0.5lb
Can you guys advice just for knowledge the type of helicopter suitable to lift 135g-200g.
I dont want quadcopter but: 1 blade,2blade,3blades, 3ch. anything. I just want some ideas of perfect models with lowest blade size possible without affecting the helicopter stability.
Thank you for reading and i will wait for your response.
I already saw this info in a website but i think for 135g-200g i can go below 450 blade size, or even 3ch:
These are MAX weights or near max weights that the helicopter will carry.
MAX SAFE lifting capabilities ….. (g, oz, lb )
315 mm blade ……… T rex 450 – 450 g, 15.87 oz, 1 lb. Keep the total flying weight under 2.2 lbs.
500 mm blade ……… Logo 10 – 1360 g , 48 oz, 3 lbs. Keep total flying weight under 9 lbs.
550 mm blade ……… 30 size , Century Swift, Logo 14 – 1587g, 56 oz, 3.5 lbs. Keep total flying weight under 10 lbs.
600 mm blade …….. T rex 600, 50 size helicoptor, Logo 20/24 – 1815g, 64oz, 4 lbs. Keep total flying weight under 11 lbs.
720 mm blade …….. Gasser , Joker – 6800g , 240 oz, 15 lbs.
800 mm blade …….. Gasser , Maxi Joker – 9071g, 320 oz, 20 lbs.
810 mm blade …….. Gasser – 11300g , 400 oz, 25 lbs.
