gyro setup help needed
im using the JR G460T with the futaba T6HX radio and in the instructions for the gyro it says to set the rudder travel adjustment left and right at a 150% and im having a hard time trying to figure out how to do that on my radio, the only thing im finding in the manual for the radio in regards to rudder is rudder offset. so how do i set up rudder travel with this radio so i can get this gyro working i dont know if im over looking something in the manual or what but right now im stumped so any help would be greatly appreciated thanks.
MI
With any heading hold gyro, the rudder ATV (Adjustable Travel Volume) in the transmitter only serves to define the yaw rate and not the servo travel. The servo travel is defined by the gyro's own ATV which may be fixed or adjustable depending on the gyro.
so if i set up the atv in my radio i should be ok then right? as per the gyro instructions its says to set the rudder travel adjusment on the transmiter.[&:] rudder travel adjustment and ATV mean the same thing right? or am i wrong.
