Raptor Building
Raptor Building
Is this heli hard to assemble? i looked through the instructions and it doesnt seem to hard but i want to know from someone who built it because i never built a heli b4, i have alot of experience with r/c cars and i never had a problem with those so im just wondering thanks everyone
RE: Raptor Building
The instructions for the Raptor's are pretty good, just follow the step by step instructions and take your time (don't rush) and you will do fine. If you run into any problems, there are lots of people on here that can help you out.
RE: Raptor Building
www.raptortechnique.com has more info on setups.
Be sure to have someone experienced check it out to make sure everything is set up and working right. It is a blast, but getting started is tough on beginners.
check
http://www.p-locate.rc-helipad.com/
for pilots near you.
check
My Feedback: (24)
MB, CANADA
RE: Raptor Building
The Raptor manual is pretty good. If you also use the manual at Raptortechnique.com you will not have any problems! The Raptor is quite enjoyable to build, just make sure you take your time and follow the guidance of the Raptortechnique site. He makes some good recommendations that are not in the manual!
Regards,
Jarrett
Regards,
Jarrett
RE: Raptor Building
P.S. are there any tough spots with building?
