HUMMING BIRD SEPERATES
My Feedback: (14)
MD
JUST GOT HUMMING BIRD GOT INSTRUCTIONS AND ANOTHER OFF INTER NET BOTH CONFLICT EACH OTHER. MY ESC'S ON ONE SIDE HAS 4 YELLOW WIRE'S (MARK IN SETS BLACK RED & BLACK RED ) WICH HAS AT THE END A RED CONNECTOR WITH A FEMALE SLOT & MALE PIN STICKING OUT.NOW IN THE INSTRUCTIONS IT SHOWS THE TAIL MOTOR BEING CONNECTED TO THE ONE SET OF YELLOW WIRES MARKED B& R BUT THE TAIL MOTOR NEEDS TWO PINS TAIL MOTOR CONNECTER HAS A B&R WITH A TWO SPACE CONNECTER FEMALEBUT ON THE OTHER SIDE OF ESC'S I HAVE TWO SETS OF BROWN RED ORANGE ONE SET IS LONGER THEN THE OTHER . & A BLACK WITH BLACK/RED STRIPE WITH A RED FEMALE CONNECTOR. MANUAL SAYS TO USE SHORTER OF THE BROWN SET TO TAIL MOTOR THESE WONT CONNECT DONT MATCH IF I GO BY PICTURE IT SHOWS USING THE YELLOW WIRES BUT THIS WONT WORK TAIL MOTOR NEEDS A TWO PIN CONNECTER COMMING OFF THE ESC BUT THEY HAVE ONE MALE & FEMALE SPOT TOTALLY CONFUSED DOES ANYONE OUT THERE KNOW HOW OR WHERE ICAN GET A WIREING DIAGRAM FOR SEPERATES [sm=drowning.gif] THANKS IN ADVANCED FOR ANY HELP
RE: HUMMING BIRD SEPERATES
Hi
I not quite sure what are you talking about. If you can show us the picture of your ESC will be great.
Here is the picture for DF circuitry:
Or go to:
http://www.gws.com.tw/english/produc.../dragonfly.htm
http://www.gws.com.tw/images/product...agonfly011.jpg
Or go to:
My Feedback: (14)
MD
THINK I MAY HAVE FIGURED IT OUT . WENT SEPERATES.ON YOUR ESC ONE GOES TO MAIN MOTOR ONE GOES TO TAIL .CONNECTORS ON MAIN & TAIL DONT MATCH ESC CONNECTORS IT WAS TRROUGHING ME OFF THE WAY IT WAS EXPLAIN IN THE INSTRUCTIONS THINK I NEED TO CHANGE THE CONNECTORS ON MAIN TAIL MOTOR TO MATCH SHOULD WORK IF NOT ILL BE BACK WITH PICTURES THANKS FOR YOUR HELP YOUR PICS HELPED OUT THANKS ALOT!!!
