RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
webra 61 engine
Old 06-26-2004 | 03:37 PM
Default webra 61 engine
I have a webra 61 engine in my helicopter it was siezed because the engine had not been run the some time I got the engien turning around using WD-40 and after run oil and methalated spriit I am woundering if the engine will atart with a good glow plug I have also stpiped down the carb wil these chemicals damage the engine
andrew
Old 06-29-2004 | 11:21 AM
Default RE: webra 61 engine
Andrew,
I thought I was the only one in this situation. I have an old Schluter heli I am rebuilding with aWebra 61. The engine was seized and I basically did the exact things you did. The engine started fine and ran as if it never sat for a long period of time.
I am going to just fly it and if it become necessary, buy a new engine later down the road.
But for now, it is running just fine.
Old 07-18-2004 | 08:38 PM
which schluter do yyou have??
I got the Magic .60. I am having problems starting the engine. I used to run fine, but the starter shat started to give me problems (broke couple of times) and now the engine is hard to start.
have you run into this problem??
Old 07-20-2004 | 08:38 AM
I have not tryed to start the engien yet but I have been told that webra engines are good and that it should go. I have got a shulter helistar 61 if the engine is hard to turn around and it giving you problems then take out the glow plug and turn it around put WD40 in until it loosens then try a new glow plug and see if it will start
Old 07-20-2004 | 11:03 AM
FLYBOY's Avatar
Webra engines rock. They are great runners. I have been using them for almost 25 years.
To get them unstuck, fill them with glow fuel or marvel mystery oil and slowly work them out. Don't force them. I soak them in marvel myself and it takes a very short time to get them unstuck. Then after it is turning totally free, start them and run them and they will be fine. Don't use any harsh chemicals in them. Just fuel or marvel will do the trick.
