Go Back  RCU Forums > RC Helicopters > RC Helicopter Beginners Forum
 Where do u look when flying? >
RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
Old 07-25-2004 | 01:47 AM
Default Where do u look when flying?
I dont want to build any bad habits. Where's the best place to look at? Am I supposed to look at the nose or the flybar and paddles (the mast or rotorhead i think it's called)?
Old 07-25-2004 | 02:14 AM
Default RE: Where do u look when flying?
i was told to watch the nose and always the nose when learning to hover but i udnno if this is the correct way to do it at all. . . as i have progressed i watch a combination of everything ,usually the nose and tail and where it is in relation to the rotor disc. u just develop a feel i think it becomes second nature i duno its a good question actaully i will be interrested in hearing other guys responses
Old 07-25-2004 | 07:07 AM
Sabot's Avatar
Personally i look at the rotor 'disk' becuase where ever that goes- the heli goes with it, i dont think it realy matters - where ever you are comfortable
Yes i was also told to look at the nose but that doesnt help because i am flying nose-out
Old 07-25-2004 | 10:05 AM
-pkh-'s Avatar
I look at the body/canopy of the heli. In a stable hover, the heli will "hang" at a certain angle. Once you can recognize what this position is, that is your "neutral" position. This means that, with no wind, you can tip it forward to get some forward momentum, and then return to this neutral position to "coast" to a stationary hover. Recognizing this "neutral" or stationary hover position will keep you from over correcting when you're trying to hover. For example, if your start drifting right, you tilt back to the left to counter the drift. However, once you've stopped drifting right, you need to get back to the neutral hover position, or you'll start drifting left, now, and then have to tilt the heli right to counter it, and you'll keep going back & forth, over correcting each way.
This is a simplified view of things, since in real life there is always some wind (sometimes lots of wind and gusts), and you'll have to fight to keep it steady, but I've found that watching the body angle/position relative to this neutral position, as well watching which way it's moving is the best way to control it and minimize over correcting your controls.
Old 07-25-2004 | 01:39 PM
thanks for the input everyone.
