Idle needle question OS, and power loss
LA
I have a raptor 30 v2 with an os 32sx-h. While running the other day in cold weather after about ten minutes the engine could not hold the the rotor rpm any more and i had to put it down or it was going to go down on it's own. Think the engine to be very lean. So i will start over on my needle adjustments. Does anyone know the starting point for the idle needle on the carb. Are possible other answer to what could have caused this power lost problem. Any info would be helpful.
Ken
Ken
LA
RE: Idle needle question OS, and power loss
Thanks allot just got done with a little trouble shooting and i think the mixture is good now. I started over at 1 1/2 turns and went from that point. Had it hovering and it was making all kind of mechanic noises and jerking around a little, so i will open her up? Not sure what to look for, but something is wrong.
Thanks again
Ken
Thanks again
Ken
