Piccolo Vibrating
RE: Piccolo Vibrating
i had this problem with my Twister. i found it was either the tail rotor not pushed in properly, or the main blades were not spaced out evenly.( they may look balanced but look closer)
Wow! what a difference a piece of electrical tape makes. Put a small piece on the heavy blade of the flybar and the whole thing setteled down. Now to get the trainning gear on and let it start hopping. I also checked the measurements and lined everything up again as you suggested Chudd, Thanks for the help. Gary
