Dragonfly 22a
FL
Dragonfly 22a
Hi all,
Got Dragonfly 22a from r/c expert. Powers up ok and all servos seem to function, but at full throttle won't lift off ground. Any ideas? Am thinking of sending it back for replacement.
Knotty
Knotty
RE: Dragonfly 22a
What are you using for a charger? Sounds like your battery is not fully charged. If your using the wall charger that come with it, you should get yourself a good peak charger, the wall chargers aren't much good. Hobbico makes a good one, and it's cheap to buy.
RE: Dragonfly 22a
hi bud.
i just got the dragonfly .. how do you turn it on. the directions dont say much or how to charge it
and all the controls . i have no clue what the 2 silver switches are for and the other controls also. so if you could plzz give me some help. cuz i have no clue. and the sim wont work so i dont have a clue what to do now. so plz get back to me. thx bud.
Lar
Lar
RE: Dragonfly 22a
Try adjusting the small paddles on the main rotor (I am new to this too, so sorry if I am not using the correct terms). I ran into a wall with mine and the angle of one of the paddles was increased. After playing around and adjusting the paddles I found that the lift was better then I first got it. According to a tread in somewhere in this forum, they say the angle should be about 15 degrees. Mine is almost at 0 degrees.
Hope this helps you out.
