need help!!
FL
RE: need help!!
Expect it to drift left when you are adding throttle and while in ground effect. Counter it with a little right cyclic. Also use small control inputs. If you have ever spun a bicycle tire in your hands and tried to move it, it takes some force and a little time for the tire to react. This is the same concept with the spinning rotor. Make your control inputs and wait for the reaction. Also, micro helis are very unstable so you're going to have to work at it. After much practice, I can hover my GWS Dragonfly in about a 3 foot circle. Try a flight sim.
