Flight sim dosent work
GA
My fms dosent work so I fired up the old honey bee 2. I dont have a clue about flying but I managed to get it statrted. I learned a little about the throttle and the right stick I am asumming this is the elevator stick. I also figured the throttle is also theaileron stick when left and right. My question is how do I get off the ground just an inch or 2?
ON, CANADA
RE: Flight sim dosent work
Providing your heli is setup right, you need to add throttle untill you see the heli get 'light on its skids'. Try making small movements with your controls and see how the heli responds to each stick movement. My suggestion would be to get the rotors spinning and move your right stick (cyclic) around. See what happens. Try getting the heli to slide around without lifting off the ground first. Once you learn what each control does, try adding more power and get it off the ground for a second or two.
It is difficult to start learning on micro helis as they are unstable and difficult to control. Best bet is to get as much stick time as possible. It will make things easier.
