Dragonfly 22d + Truflight probs
My Feedback: (-1)
ON, CANADA
Tried connecting Transmitter to PC via serial, but truflight always brings up error of not being able to recognize transmitter
RE: Dragonfly 22d + Truflight probs
I am having the same problem..I am in the process of makeing a cable that should work with the Dragonfly 22. When I am done Ill let you know how to make it.
hello everyone I am a total newbie to rc helicopters and I just bought a dragionfly. My problem is when ever Its about to lift of It tips over on the left. I tried to adjust the trim and It still doesent work any suggestions????????????????????????/
PA
ORIGINAL: thunderbird127
The trick to these things is to apply full power and jump it into the air out of ground effect.... about a foot or two. then she stabilizes
I having the same problems. But there's a light. (If you have Windows XP or XP pro)
1. Go to the folder where the programm is installed
2. Click the right mouse on the programm icon and click properties
3. Click on the tab compability
4. choose for windows 98SE Me
5. Click confirm
Then click on the programm icon. The programm should start up and run.
Succes, Raymond
5. Click confirm
Succes, Raymond
I had the same problem with the TX and Tru-Flight not seeing the TX. I took the serial port connector apart and found that the black wire had broken from it's conection and while I was looking at that the white wire came loose also. I reattached both wires and now it works fine with the program. Check them they are small gage wires and will come apart easily. Hope this helps.[8D]
